Author Topic: Recommendations for 100 MHz low phase noise OCXOs on the secondary market?  (Read 2934 times)
Offline matthuszaghTopic starter
Has anyone found any particularly good deals for low phase noise 100 MHz OCXOs that find their way into the secondary market? There seem to be quite a lot of options for 10 MHz OCXOs, but much less for 100 MHz.
The Wenzel 500-06769 are commonly found on ebay. The prices are good and the performance is decent (PN measurement here: http://www.ke5fx.com/Wenzel_500_06769_PN.png). I was hoping for something a little better, and would be willing to pay a bit more, but if there's nothing in that category I may pick up a couple of 500-06769.
Offline hpw
Re: Recommendations for 100 MHz low phase noise OCXOs on the secondary market?
« Reply #1 on: November 22, 2023, 08:51:32 am »
May look at https://kvg-gmbh.de/en/product/o-22-elpn-vhf/ or for any similar...
Offline eleguy
« Reply #2 on: November 22, 2023, 11:24:21 am »
OS400-1006-012 from the RFX claims to have -150 dBc/Hz (100Hz) but maybe that is bit pricey??
« Reply #3 on: November 22, 2023, 06:33:50 pm »
The performance on that looks great, though I expect it won't be cheap.
« Reply #4 on: November 22, 2023, 06:35:09 pm »
The price is ok, but that -150 dBc/Hz @ 100 Hz is for the 10 MHz version. I didn't see any specs for the 100 MHz unit, but I may inquire. I'd have to boost the output level too.
Offline rfclown
« Reply #5 on: November 22, 2023, 07:49:54 pm »
I recently bought something on eBay, but can't find a datasheet for it. eBay sales description said, "-154dBc/Hz@2KHz", but I haven't measured PN on it yet. I posted something asking if anyone else knew about it, and have had no replies.
https://www.eevblog.com/forum/projects/valpey-fisher-vft22h-100-00mhz-ocxo-oscillator-output-waveform/msg5157219/#msg5157219
Offline jrd
« Reply #6 on: November 25, 2023, 06:12:15 pm »
Complete solution on a single board.  Can also be GPS Disciplined. Microsemi SSM-2000/2650 https://www.microsemi.com/product-directory/embedded-clocks-frequency-references/4013-ocxo-docxo-source-modules
« Reply #7 on: November 25, 2023, 07:19:00 pm »
The PPS or 10 MHz disciplining is a nice feature, but the phase noise is actually marginally worse than the Wenzel units posted above, which is mostly what I care about here. I didn’t see a price, but given that it’s a new microsemi product with disciplining capability, I expect it’s quite a bit more expensive than the second hand wenzel units.
Offline Gerhard_dk4xp
« Reply #8 on: November 26, 2023, 11:13:40 pm »
<       https://www.digikey.de/de/products/filter/oszillatoren/172?s=N4IgjCBcoExgrABiqAxlAZgQwDYGcBTAGhAHsoBtcRRAAgFkAJALxAF0SAHAFyhAFUAdgEtuAeQz0CWPAFcATgRABfZSRiUQBVHlox4MDW2VA          >
Ah, I wanted to write "always available" as I got one on Friday
morning with 2 days delivery time,  but  no more now it seems.    :(
for abt. €100 new.
I asked ECS for the phase noise of the 100 MHz units and I was
given the .pdf without NDA.
Still a better deal than my 5 & 10 MHz recovered Chinese Morion MV89As.
Gerhard    DK4XP
« Last Edit: November 26, 2023, 11:17:39 pm by Gerhard_dk4xp »
Offline testpoint1
Hi, I just use the new KVG O.70 design a small OCXO box and PCB, the test result show -109 dB/Hz (10Hz), -132 dB/Hz (100Hz), if more than 100Hz, the noise floor is low than my reference, I can not test/verify it, but I think official chart is correct (please check the attached PDF file).
I also have another KVG O-40, if you need the O.70, I can sell to you.
« Last Edit: January 23, 2024, 01:26:31 pm by testpoint1 »
