Thanks all, good to know!
Do you need to create a different freq than the one you have?
I'm in the US, so I'm on 120 VAC 60 Hz. The project will need to also work at 240 VAC 50 Hz, but I suppose it's also easy enough to make sure the filter caps are big enough and just not worry about it. That requirement was written with the mindset of "If I'm going to buy a commercial product, I'm going to make sure it does everything I expect to need for this and future projects."
Since I need the higher voltages than 120 V, I'll have to make sure something in there is a step-up transformer as well, I suppose.
Yeah, the voltages definitely scare me. Not quite tube amp level, but I suspect the difference is not enough to matter all that much.
Even more than getting the range of voltages I want, I guess the possibility of current limiting is what really got my mind going about a commercial product. What would you recommend as a fairly straightforward adjustable current limiter? I don't mind getting my hands dirty to get this box together, I just need to avoid my penchant for turning things into a Capital-P-Project.
