WARNING: THIS WILL VOID YOUR WARRANTY ! ! ! (yes, really)
NOTE: Without the 298 Mhz SIG ID oscillator hardware, SIG ID AT MKR and SIG ID -> CF functions doesn't work. Only SIG ID function works.
Requirements
1. HP 856xE spectrum analyzer
2. Any GPIB adapter with command console software
3. 4mm HEX wrench
Procedure
1. Turn off the spectrum analyzer.
2. Remove the spectrum Analyzer cover.
3. Set the WR PROT/WR ENA jumper on the A2 controller assembly to the WR ENA position.
4. Turn on the spectrum analyzer.
5. Connect GPIB adapter to the spectrum analyzer.
6. Send the magic GPIB command to the spectrum analyzer.
Magic GPIB command: ZENTID 'HP<Model>,<Options delimited by comma>'
For example: ZENTID 'HP8560E,005,006,007,008'
7. Check the installed options from the spectrum analyzer. All is well, right?
8. Turn off the spectrum analyzer.
9. Set the WR PROT/WR ENA jumper on the A2 controller assembly to the WR PROT position.
10. Secure the spectrum analyzer cover assembly.
11.
12. PROFIT!
Search keywords: 8560E 8561E 8562E 8563E 8564E 8565E SIG ID 008 Signal Ident Signal Identification
