If yours is the 'red label' version, then it's the retail version. You may be able to find some info on Trimble's site. AFAIK, the +-12, +5 version was a special for telco use.
I've never seen the retail version so I can't give you any actual info on opening the case. However, if removing the obvious screws doesn't do the job, feel around under the labels for hidden screws.
