Author Topic: Replacement Knobs, Feet and Fittings for Test Equipment  (Read 381976 times)
Offline calin
Re: Replacement Knobs, Feet and Fittings for Test Equipment
« Reply #250 on: September 02, 2022, 03:02:45 am »
Here is my small button for Lecroy WavePro 7300A . SCAD model and STL attached.
Note: Updated the archive as somehow was corrupted
« Last Edit: January 26, 2023, 08:03:16 pm by calin »
The following users thanked this post: xrunner, AVGresponding
Offline dl6lr
« Reply #251 on: September 02, 2022, 06:28:16 am »
Siglent housing spacer for e.g. SDM3065X and SDG2042X.
Printed it with a layer height of 0.2mm and infill gyroid pattern with a density of 25%.
May I ask what design you have used to print the BNC caps? I assume you have printed them, being the same color as the spacer...
Offline BmaxTom
« Reply #252 on: September 02, 2022, 07:37:18 am »
BNC Dust Cap.
Printed it with a layer height=0.16mm, shells=3 and infill density=25%.
« Last Edit: September 02, 2022, 07:54:17 am by BmaxTom »
The following users thanked this post: AVGresponding, dl6lr
Offline BmaxTom
« Reply #253 on: September 02, 2022, 07:46:13 am »
Ethernet Dust Cap.
Printed it with a layer height=0.1mm, shells=2 and infill density=25%.
Offline dl6lr
« Reply #254 on: September 02, 2022, 02:07:44 pm »
BNC Dust Cap.
Thank you. Just tested, they had too tight fit with my prints. I measured the STL indicates 9.8mm inner diameter, but my prints came with 9.55mm inner diameter, outer diameter was fine. Had to scale up a little.
Online DavidKo
  • Country: cz
« Reply #255 on: October 05, 2022, 06:15:01 am »
I have created new power button for Advantest devices. I have measured the original button from TR6143 to replace my missing button on R7210.
The source CATPart and STL can be found on thingverse.
The following users thanked this post: AVGresponding, Peter_O
Offline CatalinaWOW
« Reply #256 on: October 18, 2022, 07:42:07 pm »
In https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/msg2318376/#msg2318376 I posted a model for HP 5040-7201 feet.  I recently had need to print some and found that errors in the model existed that my prior slicer didn't catch and there were some dimensional problems which made trimming and fitting necessary.  The attached zip file contains the corrected stl file, the corrected model in FreeCAD format, and a crude model of the wire bail foot associated with the plastic part.  The bail is pretty easy to bend up from 0.125 inch steel wire, but if you don't have at least one existing foot it is helpful to have dimensions and angles.
My apologies for the poor item naming in the model and the crudeness of both.  This poor EE is still a rank newbie at solid modelling.
Also note that these feet are still available commercially.  Printing them is only necessary if you want other colors or have other reasons for printing.
« Last Edit: October 19, 2022, 02:16:11 am by CatalinaWOW »
The following users thanked this post: xrunner, maat, AVGresponding
Online AVGresponding
« Reply #257 on: October 18, 2022, 09:46:56 pm »
The main reason for printing your own is the satisfaction you get from not having to pay (since anyone printing them already has the printer and filament). Thank you for taking the time and effort to update your design.
The following users thanked this post: CatalinaWOW
Offline CatalinaWOW
« Reply #258 on: November 19, 2022, 03:54:16 am »
This isn't quite a perfect fit for this, but I found it useful when doing the stuff in this thread.
I needed a new front and rear bezel for one of my instruments.  The old one was fragmenting rapidly, already in a dozen or more pieces.  Unfortunately the bezel is larger than the build volume of my printer, so it needed to be printed in parts.  And it was desirable to have built in alignment and features for a strong bond joint between the parts.  The two models attached form this function and also give the basic idea for those who need to split even larger assemblies.
The basic procedure is to place the target part model within the volume of the right and left splitter.  Make a copy of the target model and then use your CAD program to do the AND or COMMON process between the original and the left splitter and the copy and the right splitter.  The two results can then be printed and then bonded together with the appropriate adhesive.
I am sure this idea is so obvious to some here that it isn't worth posting, but it took me a while to come up with a nice general solution and there may be others as slow as I am.
The following users thanked this post: Kean, AVGresponding
Offline minifloat
  • loss of precision
« Reply #259 on: December 31, 2022, 09:33:09 am »
For everyone who wants to make a Tektronix 1103 probe supply clone:
3D models attached for the shroud of the TekProbe interface.
'Made 'em for this https://www.eevblog.com/forum/testgear/tek-p5205-hv-differeantial-probe-teardown-btw-what-are-the-red-and-brown-wires/msg4610551/#msg4610551 "Hacktronix" device.
br, mf
« Last Edit: January 01, 2023, 02:58:58 pm by minifloat »
The following users thanked this post: xrunner, THDplusN_bad, Neomys Sapiens, TERRA Operative, AVGresponding
Offline hpw
« Reply #260 on: May 19, 2023, 08:52:59 am »
After long FreeCad trial and understanding as in addition required 3D printing cycles too... I have it now  :phew:
but as 3D printing with matching colors is still an issue as it looks not available  :palm:
BTW: it is for LeCroy 6000, 7000, 8000 models..
Hp
« Last Edit: May 19, 2023, 09:35:59 am by hpw »
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #261 on: May 19, 2023, 11:08:36 am »
Good work, but for color we sometimes need to use high quality model paint, such as Tamiya (flat or gloss), to get a closer color match.  :-+
Tamiya Paint
[hp] Hewlett . Packard
Offline ZigmundRat
« Reply #262 on: May 20, 2023, 12:38:03 pm »
Looks like a nice fit. Can you please share files here? Thx.
