Author Topic: Replacement Knobs, Feet and Fittings for Test Equipment  (Read 481083 times)
Offline BlownUpCapacitor
  • pssSSHHH BOOM!
Re: Replacement Knobs, Feet and Fittings for Test Equipment
« Reply #275 on: November 10, 2023, 08:05:03 pm »
Tektronix 22xx series Power cable wrapping holder... thingy... I don't know what they are called. Used them on my Tek 2230 and they work well. The design could maybe be improved a little bit, but not by much I think.
Tinkercad link here: https://www.tinkercad.com/things/amQ4XpQkk1r-tek-power-cable-standoff
Love the smell of burning capacitor electrolyte in the morning.
The following users thanked this post: salvagedcircuitry, TERRA Operative, AVGresponding
Offline RikV
« Reply #276 on: November 17, 2023, 01:19:49 pm »
On my HP5335A the stem of the power button was broken off. I will surely find a suitable power switch in my spares bin but the button cap is an other history. Anyone knows of a 3D printable version? HP part# is 5040-0201, it is square, about 9mm.
Offline Kosmic
« Reply #277 on: November 17, 2023, 07:36:11 pm »
I reproduced the feet of my Solartron 7081. Should technically also fit the 7071 7061 and others.
« Last Edit: March 06, 2024, 04:07:22 am by Kosmic »
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #278 on: November 18, 2023, 01:22:31 am »
I'm in the same situation.
I replaced the switch too and need a new button.
I have another 5335A on the bench, so maybe I'll pull the button off that and draw up a 3D file soon.
Stay tuned....
Offline DavidKo
  • Country: cz
« Reply #279 on: November 20, 2023, 08:02:46 am »
I have created for my Yokogawa WT130 rear and bottom foot. It will probably WTxxx power meter series and devices in same box.
Rear foot
Bottom foot
  • Country: jp
« Reply #280 on: December 03, 2023, 05:11:35 pm »
I just drew up the rear foot/handle for my HP/Agilent 8648C, part number 08647-40003, and stuck it up on thingiverse too.
I guess it'll fit some other instruments too.
https://www.thingiverse.com/thing:6343540
The following users thanked this post: salvagedcircuitry, AVGresponding, RikV
  • Country: jp
« Reply #281 on: December 04, 2023, 04:21:19 pm »
And a power button for the HP 5335A Universal Counter.
I haven't checked fitment so some experimentation will be needed with the hole that fits over the plunger in the button, let me know how it goes. :)
https://www.thingiverse.com/thing:6352529
The following users thanked this post: ch_scr, AVGresponding, RikV
Offline ch_scr
« Reply #282 on: January 11, 2024, 09:21:27 am »
After getting my hands on two IET Dekapot's, I've had to make new spacer disks to get the "index support" into proper position.
The attached models are about the thickness of 2 or 3 of the spacer disks combined.
If you have no spacers disks and want to use it stand-alone (no additional front panel thickness) the 6mm one should be just right.
I've used the 4.2mm one with one spacer disk to the same effect.
Your slicer should be able to scale each model in just the Z direction to an individual thickness.
The following users thanked this post: HighVoltage, AVGresponding
Offline Kosmic
« Reply #283 on: March 05, 2024, 11:44:32 pm »
Prema 5017 foot.
Use M3x6 screw.
« Last Edit: March 05, 2024, 11:50:01 pm by Kosmic »
The following users thanked this post: xrunner, AVGresponding, bastl_r
Offline scopeman
« Reply #284 on: March 10, 2024, 03:00:19 am »
Looking at the bad photo I am actually wondering if they were made from the same soft plastic on the 5300's I made new feet for rather than a rubber. What was left of mine basically crumbled into pieces and the rear shot of Daves looks like that same sort of issue?
Edit Adding the 35mm Foot here due to the 1Mb file size limit   |O I will add it to the link index on the front page and leave both available.
Modded Fusion file and both STL'in the Zip for 6mm Long Screw and the Genuine HP screw options.
Hello Bean,
Any chance you could export the file in STEP also? I want to play with it in Alibre but it will not import Fusion360 files directly.
Thanks,
Sam
W3OHM
W3OHM
Offline Kosmic
« Reply #285 on: March 12, 2024, 12:17:58 am »
TPI 440 Tilt Stand.
Printed at 0.2mm, 25% infill with PETG
« Last Edit: March 12, 2024, 01:49:12 am by Kosmic »
The following users thanked this post: xrunner, ch_scr, AVGresponding
Offline Finnaaah
« Reply #286 on: March 26, 2024, 12:32:34 pm »
Knobs for the Array 3720A or any e-loads with the same posts.
  • Country: jp
« Reply #287 on: March 26, 2024, 04:40:34 pm »
Whaaat whaaat.
A complete reproduction front panel for a HP 8648 series function generator?
Ok, here it is. :)
https://www.thingiverse.com/thing:6518453
« Last Edit: March 26, 2024, 04:43:32 pm by TERRA Operative »
