Products => Test Equipment => Topic started by: theleakydiode on June 06, 2017, 11:24:23 pm
Title: Replacing rigol probes noob question
Post by: theleakydiode on June 06, 2017, 11:24:23 pm
Hi, my DS1052E included probes are starting to get worn out and are going intermittent so I'm looking to replace them. Looking at the official Rigol probes I can see that prices are quite high so I'm probably going with the third party route.
My question is are these probes universal or do I need to look out for anything to make sure they will work with my scope? Does the probe compensation adjustment work across the board or do I need to get ones that match the supplied RP2200 probes?
Thanks!
Title: Re: Replacing rigol probes noob question
Post by: theleakydiode on June 06, 2017, 11:36:24 pm
At 50MHz frequency, it's likely any probes will work. Of course, you need to adjust low frequency compensation, but high frequency compensation should be free of adjustment for most of the cases.
Thanks. I guess what I'm worried about is not having enough compensation range to get the perfect sqaurewave when I come to calibrate them with probes trimmer adjustment.
Post by: ebclr on June 06, 2017, 11:48:47 pm
The concept is universal, Must have a BNC must fit 1 M input impedance.
But probes have specs like,  bandwidth and very important  capacitance, the lower the better
For general purpose low noise low frequency, even a wire soldered to a BNC will work, But for high noise high-frequency measurements, the probe is a  critical element of the equation.
Does not have sense to have  to have high-end probe on low-end oscilloscope, the idea is to match both, Or have a little bit better probe.
Based on the class of your instrument will not be hard to find a compatible probe who wil work fine.
http://www.syscompdesign.com/assets/images/appnotes/probes.pdf (http://www.syscompdesign.com/assets/images/appnotes/probes.pdf)
Post by: CopperCone on June 07, 2017, 12:33:10 am
I recommend going on eBay and searching for tektronix or HP probes. You will get stuff alot better then your scope is capable of for cheaper then buying from a website is.
Post by: Electro Detective on June 07, 2017, 12:43:06 am
Rigol and Siglent owners sell their new probes sometimes on Ebay,
because they either prefer their own, or have extras,
or their DSO got stolen, dropped,
or cooked measuring the mains or their bug zapper
They usually go cheap and good performers afaict   :-+
Post by: technogeeky on June 07, 2017, 12:50:10 am
Thanks!
If you want a guaranteed compatible probe, the key figure to look out for is that the compensation capacitance range of the old probe match the new probe. It doesn't need to match perfectly; but, the more overlap the better.[1]
From this thread (https://www.eevblog.com/forum/testgear/scope-probes-as-supplied-by-rigol-for-the-low-end-scopes-a-discussion/) (you can't skip reading this unless you really want to...)
As is mentioned in that thread by Dave,
I also want to point out the OP is in the situation where, since he has existing benchmark probes, he can compare them to the conspicuously cheap overseas probes directly. Some of them really are very nice.
[1] What we're doing is matching the parameters of the oscilloscope's inputs, but indirectly. We're making the assumption that the probes that came have a suitable adjustment range already, and that if we stay in the same range we'll be fine.
Post by: sgub on June 08, 2017, 03:13:33 am
I've been using Tek TPP0101 probe on Rigol DS1102E and MSO1104Z, it's compensation range is ok and works great (slimmer than rigol probe).
