100.1 says that If ADC not getting correct measurement of 153.6M +/-1.2M counts, then test fail.
So measure 0V at A/D in first. If it's correct, check operation of ADC circuitry , digital side:
U154 74HC175, 12MHz clock from Y102, +5VR rail. Check U146 74HCT14.
Is your ADC digital part custom Keithley ASIC or ALTERA MAX CPLD?
Then proceed with analog side of ADC - (U149, U148, Q127,Q131, stuff around U138, U137, U142, U153, Q132,Q133, U145).
You should have +14, +15, -14, -15, +20, -20V rails correct.
