Author Topic: Why can't I netcat into my Rigol DS2072A ? Linux, LAN, etc.  (Read 1281 times)
Offline LinuxGuy123Topic starter
« on: August 23, 2022, 05:42:02 pm »
Hi.
I'm trying to send some SCPI message to my DS2072A and I'm not getting any responses.
It is connect to my local network via DHCP at 192.168.1.125.  I can ping it with no problem.
My workstation is running Fedora 36 Linux.
I've tried to send several commands, such as:
echo ":DISPLAY:DATA? ON,OFF,PNG" | nc -w1 192.168.1.125 5555 | dd bs=1 skip=11 of=image.png
echo “:SYST:LANG?” | nc -w1 192.168.1.125 5555
# echo ":DISPLAY:DATA? ON,OFF,PNG" | nc -w1 -4 192.168.1.125 5555 | dd bs=1 skip=11 of=image.png
^C
0+0 records in
0+0 records out
0 bytes copied, 136.488 s, 0.0 kB/s
I've tried this both as a regular user and as SU.  What am I missing ?
Thanks
Do I have to enable something on the scope to enable it to reply to SCPI commands ?
Are there any simple tests othre than ping <scope IP> to test why it isn't work ?
My scope is software version 00.03.03.sp1.  Do I need to update it before SCPI commands will work ?
« Last Edit: August 23, 2022, 06:22:27 pm by LinuxGuy123 »
Offline gnif
  • Views and opinions are my own
    • AMD
Re: Why can't I netcat into my Rigol DS2072A ? Linux, LAN, etc.
« Reply #1 on: August 23, 2022, 06:11:28 pm »
There is no need to do this as `root` as your regular user can open outgoing ports using netcat just fine. While I can't speak to the issue you're having as I am not familiar with the device or the protocol, you should know that unless you specify `-n` to `echo` it will also output a carrage return, which might be messing things up.
For example
echo -n ":DISPLAY:DATA? ON,OFF,PNG" | nc -w1 192.168.1.125 5555 | dd bs=1 skip=11 of=image.png
SMTS Software Development Engineer @ AMD
« Reply #2 on: August 23, 2022, 06:28:24 pm »
OK.
Are these commands supposed to be sent with a CR or a CR/LF or nothing ?
Thanks for the reply.
Offline gnif
    • AMD
« Reply #3 on: August 23, 2022, 06:37:15 pm »
That's what I meant, I am unsure if they are, but the `echo` command by default will output a line-feed (\n) if you do not specify the -n switch if you are unaware. This can and has caught me out on occasion in the past.
You can explicitly output a line feed (\n) or a carriage return (\r) with `echo` by using the -e switch, for example
echo -ne "SomeText\r\n"
As to why it's not working, if it isn't this, someone here with more experience will need to provide an answer I am sorry.
« Last Edit: August 23, 2022, 06:39:23 pm by gnif »
« Reply #4 on: August 23, 2022, 07:21:07 pm »
I still can't connect it over the LAN, but USB works.
echo "*IDN?" > /dev/usbtmc0; cat /dev/usbtmc0
RIGOL TECHNOLOGIES,DS2072A,DS2D164752690,00.03.03.SP1
I'll update the firmware and report back.
Offline mag_therm
« Reply #5 on: August 23, 2022, 07:37:01 pm »
I use ssh on linux but have not used nc, so not familiar.
Firstly, are you sure that nc is listening as a server on the Rigol?
To check that , you could run nmap like this, (install it first if you don't have it).
nmap -Pn 192.168.1.125
IT takes a minute or two. That will tell you all ports that are open and have servers.
Here is an example of nmap response:
$ nmap -Pn 192.168.1.16
Starting Nmap 7.80 ( https://nmap.org ) at 2022-08-23 15:31 EDT
Nmap scan report for 192.168.1.16
Host is up (0.0054s latency).
Not shown: 998 filtered ports
PORT     STATE SERVICE
21/tcp   open  ftp
3389/tcp open  ms-wbt-server
Nmap done: 1 IP address (1 host up) scanned in 4.89 second
« Reply #6 on: August 23, 2022, 09:47:58 pm »
$ nmap -Pn 192.168.1.125
Starting Nmap 7.92 ( https://nmap.org ) at 2022-08-23 15:30 MDT
Nmap scan report for 192.168.1.125
Host is up (0.037s latency).
Not shown: 997 closed tcp ports (conn-refused)
PORT     STATE SERVICE
80/tcp   open  http
111/tcp  open  rpcbind
5555/tcp open  freeciv
Nmap done: 1 IP address (1 host up) scanned in 0.70 seconds
I updated via USB.  I'll post the process in another thread.
My network connection works now.
$ echo "*IDN?" | nc -w1 -4 192.168.1.125 5555
RIGOL TECHNOLOGIES,DS2302A,DS2DXXXXX,00.03.06
Turns out these scopes have an HTTP server in them.
Thanks for your help.
« Last Edit: August 23, 2022, 10:12:08 pm by LinuxGuy123 »
« Reply #7 on: August 23, 2022, 10:13:25 pm »
Have you logged into a Rigol scope using ssh ?
Offline mag_therm
« Reply #8 on: August 23, 2022, 11:06:22 pm »
No, I have a new GW Instek GDS 1202B.
So far I use USB media in the front socket  to transfer files.
There is a big manual about comms but I have not had time yet to get into it.
But if your Rigol had ssh server up, you would have seen it on nmap.
