Author Topic: Reverse Engineering a HP HIL Interface Keyboard with a Rigol DS1054Z  (Read 569 times)
Offline andybarrett1Topic starter
Hi
Thank you for reading ....
I want to look at the HP-HIL interface / Protocol with the idea of building a keyboard with a few less keys (Its to make operation a little less cluttered)
In short I need to understand and replicate a few keys from an existing HP HIL Keyboard
The Serial options on the DS1000Z seem a little too specific  linked to SPI / RS232 etc
So was wondering if I could simply use the waveform record .... Hit the keys on the keyboard that are of interest and play back later ?
Or is there another way ...
My Rigol is currently locked away a good way from here ...... So looking for ideas or if yes / no befor I go digging it out :-)
Thank you again
Andy
« Last Edit: August 04, 2024, 04:32:58 pm by andybarrett1 »
Offline edavid
Re: Reverse Engineering a HP HIL Interface Keyboard with a Rigol DS1054Z
« Reply #1 on: August 04, 2024, 05:16:05 pm »
« Reply #2 on: August 12, 2024, 07:19:02 am »
That helps 😁
Thank you 👍
Andy
Offline DavidKo
  • Country: cz
« Reply #3 on: August 21, 2024, 12:14:48 pm »
You can check https://groups.io/g/VintHPcom/topic/hp_hil_and_usb/68643874.
It is the thread to http://www.dalton.ax/hpkbd/hil/. I have not build one with USB only with PS/2. For proper PS/2 mouse functionality you need to add pull up resistor - some mice can work without it. I'm not sure if the schematic on dalton site is already updated.
HP-HIL documentation
« Last Edit: August 21, 2024, 12:16:54 pm by DavidKo »
