Author Topic: Solartron 1285A DC Potentiostat Galvanostat, what animal is this ?  (Read 678 times)
Offline DC1MCTopic starter
Hello everybody, I've seen $subject in this  >:D bay link:
eBay auction: #https://www.ebay.de/itm/324067594048?ul_noapp=true
After reading a bit of datasheet:
https://www.ameteksi.com/-/media/ameteksi/download_links/documentations/1285/model-1285.pdf
I'm still wondering if it could be used for something, or at least a source of good stable components ?
Cheers,
DC1MC
Online Kleinstein
Re: Solartron 1285A DC Potentiostat Galvanostat, what animal is this ?
« Reply #1 on: February 09, 2020, 09:44:58 am »
I don't think this part would be very useful for other than the intended use. At best one might get a kind of low power lab supply (20 V up to 1 A at lower voltage ?). Maybe a little like a low end, limited range  5.5 digit source meter with an extra sense input (a kind of 3 wire mode).
The SW may be limited in control.
I won't expect really high end components. At least one would not need them for the specs. Likely CMOS OPs and SD-ADC chip (e.g. LTC2400).
