I missed the 8018S. I think I will try a set before I commit to going for the deluxe set. I want to see how they feel in hand. I don't want to spend that much money if they aren't comfortable for me. $17 is one thing, $80 is something else. I just need a basic set of probes to fit the HP3466A on the company side of the bench. I don't need any attachments, just basic probes for my use there.
On that logic, you'd need to get leads only in both series' in order to try out fairly.
That said, I've used Fluke, Pomona, Probemaster, Brymen, and too many cheapies I don't care to remember. And I'd take EITHER of the Probemasters ANY day of the week over the lot. They're that good IME in both comfort and performance.
The 8000 series probe bodies will feel a bit short initially, but it doesn't take long to get used to them. The reason IME is the thick portion behind the finger guard of the softie body has a hard plastic tube inside it. But as it tapers back down (say last 1/3rd or so), the hard plastic stops and the remaining gray rubber serves as the strain relief.
The 9000 series are hard plastic with large diameter finger guards, and the handle gets longer once the straight retractable banana is plugged in (makes a very nice and stable probe). Feels like a more robust version of a typical decent probe.
For me, the biggest difference is in terms of fit-for-purpose. For example, the 8000 series' Test Lead Master Kit would be ideal for HVAC repair IMHO (vibrating equipment tested live = threaded accessories make a lot more sense from a safety POV & multiple length options on the order page).
Where as the 9000 series stuff seems primarily for bench use (faster accessory changes, fixed standard length). Need an accessory instead of the probe? Just unplug it and attach the appropriate end you need. Quick and easy. No heavy weight hanging off your test point to pop off on you in the middle of a measurement either (royal PITA when this happens IME).
You might also note that the 9000 series kits only offer rt. angle or straight retractable banana's on the meter end as those are all that's needed for bench gear. They offer others as custom leads only.
Look at the website a bit closer. You can get them with around 8 different banana plugs. I assure you I'm not inventing this in my head, because I own these.
Exactly.
It's only the 9000 series kits that only offer rt. angle & straight retractable banana's as standard options (even the rt. angle use retractable ends for the opposite ends of each test lead, as that's what what will mate with their accessories).
If for some reason you need a an end on a 9000 lead that's not available, they will make them custom for you (no MOQ either).
