Ok, I understand what you mean
By now, I sent it back using the Amazon return policies... meanwhile I try to see if there's a better alternative with good frequecy counter support... looking to:
- UT171B/C: they use the same HY3131 ot the Agilent, but no maximun frequency counter is reported in the datasheet... in the manual they say 10MHz, while pinsonne-elektronik.de reports 60MHz
- UT181A: it's more complete with ES51997 that supports 60Mhz
- VC890: the same as UT181A
- VC880: use the same ES51966 of UT71x with 400 MHz support
- a cheap UT61E with its 220MHz
I never thought to find hard in searching on a good multimeter with near 100MHz
Brymen are good but stops to 1MHz
Other such Agilent stops to 10MHz
I don't know... if I don't find nothing I may try another UT71... maybe not from chinese seller but from German seller
