Author Topic: Review of the Korad KEL103 programmable load.  (Read 3517 times)
Offline FriedMule
  • Can make even the simplest task look imposible.
« on: March 18, 2019, 02:41:09 am »
We have all been there, in trying to test a power supply, solar panels or battery's, we budge something together that shall make it out to bee a reasonable load, often do we use a lot of time to make sure that our load is somewhat okay or at least simulates the reality fairly, but nothing do replace a dedicated load that are already made for the job.
Then what to choose? You could naturally just get a Kikusui that properly are the leading manufacturer but not all of us has that amount of money, you could also just get a cheap no-name Ebay model, but are you then much better of then DIY?
We all know the BK Precision, Maynuo and the Rigol, funny enough Siglent does not make any loads, but is that all, aren’t there more in that price rang or maybe even better? In my search for an answer to that, I’d stumbled upon the Korad KEL-103 that is the same brand as my often used Korad 3305P power supply. Unfortunately could I not find much about it, until I’d contacted https://www.sra-shops.com/ that have almost all what Korad are making for private consumers, including the KEL-103 electronic load.
Many do all know what level of quality the Korad brand is and I would really like to know if the KEL-103 Electronic load was of high quality before buying / recommending the unit, so I contacted SRA Shops and asked if I could borrow a unit, and told them about my plan on reviewing it, before sending it back with thanks. SRA Shops was wary nice and liked my idea but offered me one for free, maybe knowing that after a tear-down, it may be worse off? When that is said, SRA Shops has in no way asked me to say anything in any particular way!
It has now been a month since I received the KEL-103 and I have tried to all from pampering to torturing it with some great and positive results.
But first, what do you get when buying the KEL-103 from SRA Shops?
The unit comes in a single layer cardboard box with nice padding to protect the unit. In the box, you get a professionally produced CD not that home copy stuff, a power cable, USB cable and a set of thick soft test cables. The manual is on the CD.
I have to say that the test cables caught my attention, they felt really solid and heavy I have no doubt that they can handle the 30A that KEL-103 can load, they have a really good feel to them and is wary bendable, down to 2 inch diameter without stressing them, pretty amazing.
The unit itself do also feel like a solid unit with a lot of holes in the bottom and back for the active cooling.
To me does the KEL-103 electronic load, looks a lot like the good old Keithly units, like the 2001, 2015 and so on.
KEL-103 has four feet's where the two in the front can fold out so the unit stands with a slight angel, that make it easy to use, the display is wary clear without been to bright, I feel that it has found the balance and you will have no problem reading the numbers on the front, not even outside in the sun.
So how good is the unit?
In the shortest possible way, can I only say that if you love your Korad PS, you’ll also be glad for the KEL-103 Electronic Load! They are of the same quality and build.
To test the unit I kept a constant room temperature at 21,5 °C = 70 °F I started by connecting my Korad power supply to the electronic load, so a Korad PSU to test a Korad load, what can be more fair?
I did a lot of tests with different configurations but the largest difference was when the unit did stay turned on from yesterday but in rest run and then work for 4 hours at 18V 20A where I got a fluctuation of 6mV over the entire period. That's pretty impressive.
Under the tests I did not find the unit to make to much noise, okay you should avoid to put it in your bedroom but for an electronic load, the noise is acceptable.
This unit has a lot of functions with 100 memory functions, 5 presets you can program for easy change to what you use most. The unit is fairly easy to use when you know how, what I am saying is that you have to read the manual to get any good usage out of it. It’s not a unit that you just put into your lab and start using, because there are some functions that you have to read how to use before you get frustrated. But after reading this thin 25 page manual, you should easily be able to use it.
I had looked forward to the tear down and I have taken some picture but every chip, capacitor and what not, is covered by a black epoxy that make it nearly impossible to get much out of the tear down.
Conclusion: It is a unit you will like if you like the Korad brand, low noise and fairly stable, I do only not like that all components are without any kind of indemnification.
I think that this unit is worth the money and easily can compete with other brands like BK Precision and so on. The many functions and settings do make for a complete unit, you will not miss anything in your home-lab, unless you are working whit special advanced needs but then you may also own gear fare exiting this price range..
Facts:
For more info, please visit: https://blog.sra-solder.com/article-categories/power-supplies
« Last Edit: March 18, 2019, 05:02:35 am by FriedMule »
The following users thanked this post: Teti, salvagedcircuitry
Offline tautech
Re: Review of the Korad KEL103 programmable load.
« Reply #1 on: March 18, 2019, 03:12:10 am »
One is coming:
Avid Rabid Hobbyist
The following users thanked this post: salvagedcircuitry
Offline xani
« Reply #2 on: March 18, 2019, 08:17:46 am »
So I've got one too (the KEL102, lower power one) and so far it seems to be a solid piece of kit, and surprisingly quiet one (and I think fan just stop at low load). The biggest annoyance I found is as FriedMule mentioned that using of any non-basic function pretty much requires a manual because display does not display enough info to be used without it.
For example some modes lets you specify amperes of load and A/us but for both steps it just displays A on screen so you have to remember the order or refer to manual.
Battery mode is also a bit... derpy because you *have* to set both time and Ah which means you can't make (or at least I haven't found a way) discharge that lasts more than 9999 seconds (typing 0 just changes it to 0.001). You can just use normal CC mode but that won't show you Ah consumed...
If someone wants me to test anything specific let me know :)
Offline colorado.rob
« Reply #3 on: March 18, 2019, 02:23:22 pm »
One is coming:
When?  Weeks, months, years from now?   :-//
My US vendor (as of last week) could provide no information at all as to when it will be available.
The following users thanked this post: BillB
Offline salvagedcircuitry
  • Electrical Engineer | Hobbyist | Camera Enthusiast
    • salvagedcircuitry
« Reply #4 on: March 20, 2019, 12:04:03 am »
@FriedMule Awesome review man!
I was on the verge of buying one of these and testing it out, but I happened to score a pretty fancy dc electronic load not too long after. I paid about 2.5x what this Korad costs, but it's a whole lotta dc load for one to handle  ^-^. I'm still reading the manual on mine  ;D
I'm glad this turned out to be a pretty sweet unit.
SalvagedCircuitry
www.salvagedcircuitry.com
Offline tautech
« Reply #5 on: March 20, 2019, 04:23:11 am »
One is coming:
As usual release date is a secret however mid (this) year was mentioned. So a couple of months or so.  :(
Avid Rabid Hobbyist
Offline nctnico
« Reply #6 on: March 20, 2019, 10:55:39 am »
Why do so many loads have these stupid binding posts which don't take 4mm banana plugs? There are 4mm binding posts which are rated for 35A so that isn't the problem.
« Reply #7 on: March 20, 2019, 05:08:01 pm »
I suspect that it is because EU safety rules requires fully-sheathed banana plugs, which makes also providing reasonably-sized binding posts difficult for smaller form factors and would make the product more expensive to produce.
I just discovered that the reason for this rule in the EU is because mainland European power outlets are a perfect receptacle for a 4mm banana plug -- and a match for the 19mm spacing of a dual banana plug connector.
Offline JeffreyLatter
  • Electronics Technician
« Reply #8 on: March 20, 2019, 05:23:25 pm »
Thank you for the great review!  :-+
Have been thinking about buying this one - this probably does it..   :-DD
Offline Commander_Spock
« Reply #9 on: April 29, 2019, 01:51:06 pm »
outside of ebay anybody knows where i could find it in the european union ?
Offline txx
« Reply #10 on: August 07, 2019, 10:24:20 am »
It looks like this RND brand is a rebrand of Korad. And that they can be bought from elfa: https://www.elfadistrelec.dk/da/programmable-electronic-dc-load-120v-150w-30a-rnd-lab-rnd-320-kel102/p/30126023?track=true.
Regards
Offline plazma
    • Homepage
« Reply #11 on: October 04, 2019, 02:00:56 pm »
Farnell got it rebranded as TENMA. Quite a good price. https://uk.farnell.com/tenma/72-13210/dc-electronic-load-prog-30a-120v/dp/2848407
