I will try to check why the 'noise' on the trace and update to the latest FW soon.
I presume - this was an issue before with earlier FW??
Also - as mentioned in earlier post - the overshoot problem is only on CH1 - did you experience similar?
Thanks, yes I know there was a FW update which reduced the noise somewhat but looks like you're already ahead of that version anyway so probably the environment to a degree.
I wish there was a better X-Y mode resolution though (I know its a tricky process with digital sampling) but thats another topic.
My first unit bought March was the one with that overshoot on channel 1 only, which made it rather obvious. It was a 1.00 unit - I spent a bit of time trying various things but the supplier intervened and swapped with another. That one had flat, consistent response on all 4 channels, so I was happy until the touchscreen threw a wobbler after some time powered up.
It went back for repair in May (really should have been replacement then too as I believe was DOA, just undiscovered), but anyway the board got replaced rather than the screen, so it came back with the same screen fault and a new 1.01 board that then had overshoots on all 4 channels...
It's back in for repair now, and offered new replacement, but that has overshoots on all four too so I'm in the middle of trying to get that sorted before they send it me - I don't really want a refund, it doesn't really help anyone - I just want a working, consistent, trustworthy device, and if we can get this issue addressed it'll serve a greater purpose!
NoisyBoy, thank you for those images, that's a great help too. I'll point Rigol and my supplier at this thread again (and the poll if it gets any responses)
