Author Topic: RF connector input (R&S FSP7)  (Read 441 times)
Offline pogrebnushkinTopic starter
  • Country: ru
« on: June 18, 2024, 01:23:17 pm »
Hi. I try to find a partnumber rf connector of R&S FSP7 spectrum analyzer. Maybe somebody could help me with it. Thanks
Offline Kean
    • Kean Electronics
Re: RF connector input (R&S FSP7)
« Reply #1 on: June 19, 2024, 06:31:54 am »
That is a whole cable assembly.
The damaged N connector looks like it could be from the Huber+Suhner 25_N-50 series.
Offline tooki
« Reply #2 on: June 19, 2024, 06:42:27 am »
Indeed, getting the connectors is the easy part; getting the rigid coax, assembling it to the connectors, with the correct ferrites in the right spots, and then bending it to shape, not so easy!
I don’t have enough experience with rigid coax to tell whether that connector is soldered or crimped; if it’s soldered, maaaaaaybe it’s possible to replace the damaged N connector only.
Offline Kean
    • Kean Electronics
« Reply #3 on: June 19, 2024, 06:57:53 am »
Exactly the same thoughts here.
As is common, the OP doesn't really provide enough info, and seems not to have done any initial research.
If they use a FSP7 then they would presumably also have enough RF experience to know this stuff.
