Author Topic: IFR COM-120A need help  (Read 3286 times)
Offline mrf245
  • Country: cn
« on: September 15, 2014, 02:49:56 am »
hello everyone,this is my first topic here.
I have an IFR COM-120A service monitor,now the"deviation meter"failed in self-test.And I tried to replace most of capacitors on "BASEBAND TRAY"but it still failed.
Another problem is it had OPTIONS "OUTPUT AMP"in menu,so in operation it display AUX port can output +13DBm max,but I check infact no hardware OUTPUT AMP module in it,so if AUX out level less than-13DBm,no problem;but up to -13DBm,actual output is -13-26(amp gain)=-39DBm,oh my good....
so does anyone know.....
the calibration password of it??It calibration out of date.I don't know if re-calibration maybe OK.
and how can I cancel the option in menu?(maybe this CONTROLLER TRAY was replaced by others,not matched the machine)
I'm looking forward to someone can tell me,thanks.
BH7JUO Mark
Offline mrf245
  • Country: cn
Re: IFR COM-120A need help
« Reply #1 on: September 16, 2014, 03:11:33 am »
anyone could help?
BH7JUO Mark
Offline Mikecomm
« Reply #2 on: October 21, 2014, 02:21:11 am »
Hello i have the same problem  i am looking for password to ajust 1mhz up  ican not ajust or make change
i got IFR-120 A MODELO ..
IF I FIND SOMETHINK  WILL SEND TO YOU LOOKING  FOR MANUAL TO . ONLY IFR-120C
MIKE
Offline try2fix
« Reply #3 on: August 06, 2019, 09:28:22 pm »
Password FMYSVCD
