Author Topic: Rhode and Schwartz RSCommander software  (Read 1638 times)
Offline boumboauto
« on: February 09, 2018, 06:58:46 pm »
Hello,
I was looking for R&S software review, especially to control a RTB2000 via LAN network using RScommander. I wanted to know how the oscilloscope interface works and how eaily it can be configured remotely.
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Rhode and Schwartz RSCommander software
« Reply #1 on: February 09, 2018, 07:08:38 pm »
You don't generally need any software for most remote operation on the RTB - you have a full front-panel interface via the web interface, and using the USB interface you can pull various file formats of the latest capture off a virtual USB drive
Day Job: Mostly LEDs
The following users thanked this post: boumboauto
Offline boumboauto
« Reply #2 on: February 09, 2018, 07:36:37 pm »
Thanks, that's good news, I didn't know how RTBs behaved once plugged. If they contain a tiny web server and http interface that's perfect.
I want buy that for work because  they use 10 "real" bits ADCs and seems to be very good for the price
Thanks for the info
Offline boumboauto
« Reply #3 on: February 09, 2018, 07:38:22 pm »
Oh Mike by the way, I was looking at your review of the Owon vds3104 last night,
great teardown and demo of the software ! I'll buy one of these as well for field operations, only 8 bits but they are ok for the job.
« Reply #4 on: February 10, 2018, 01:19:16 am »
For portable use, unless you really need the small size, I'd go for the Micsig Tbook Mini over the Owon - bigger screen, more traces, better UI
RTB2004 web interface :
https://youtu.be/mcgJSKxj0i0?t=269
Data access via USB
https://www.rohde-schwarz.com/uk/products/test-measurement/oscilloscopes/rtb2000videos/rtb2000-import-and-export-of-data-and-settings-via-usb_231068.html
Micsig Tbook Mini
« Last Edit: February 10, 2018, 01:20:53 am by mikeselectricstuff »
Offline lundmar
« Reply #5 on: February 10, 2018, 02:26:22 am »
Hello,
If you are on Linux you could give http://lxi-tools.github.io a try. It recently gained screenshot support for the RTB2000 series (tested with RTB2004).
« Last Edit: February 10, 2018, 02:28:34 am by lundmar »
https://lxi-tools.github.io - Open source LXI tools
https://tio.github.io - A simple TTY terminal I/O application
http://dc-power-supply.github.io - OSHW DC power supply project
Offline boumboauto
« Reply #6 on: February 10, 2018, 02:14:57 pm »
Thank you all for your help!
