Author Topic: Ridiculous Prices  (Read 12100 times)
Offline lgbeno
Ridiculous Prices
« Reply #25 on: August 06, 2013, 04:17:28 am »
Pretty sweet scope 33GHz is crazy.  We used a similar 12GHz one to demodulate a 528MHz wide UWB signal with 8GHz center freq.  There we didn't use a fancy probe, just piped RF into the scope.
Sent from my iPhone using Tapatalk 2
Offline Salas
  • Country: gr
Re: Ridiculous Prices
« Reply #26 on: August 06, 2013, 07:04:47 am »
Because they only sell dozens or maybe hundreds of them. Those who need it don't care what it costs.
Sounds exactly like the case of high-end turntable arms.
Offline Stonent
« Reply #27 on: August 06, 2013, 07:12:17 am »
Actually a turntable arm might be perfect for mounting a probe vertically for placing on a test point.
Offline jpb
« Reply #28 on: August 06, 2013, 09:49:15 am »
If you're selling expensive instruments then extras are down in the price noise and you charge for the hassle rather than the thing itself. I remember being slightly shocked that the  company I worked for sold RS232 to GPIB convertors for a mark up of at least 4x the cost of buying them retail. The point was we needed to sell them at such a level to make it worthwhile and customers spending 10s of k$ would regard something under $1k as too minor to be worth haggling over or even thinking about.
It is like when NASA pay 10s of k$ for a cup-holder on a space shuttle (or is that a myth?)
Offline echen1024Topic starter
  • 15 yo Future EE
« Reply #29 on: August 06, 2013, 03:20:52 pm »
Probably just better used as a bargaining chip. "Sir, may I have 2k off this Infiniium 90000Q?"
"No, but I'll give you 2 probe holders and  pack of solder down probes FREE!"
"*gasp* That's a great deal! Sure!"
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
Offline G7PSK
  • It is hot until proved not.
« Reply #30 on: August 06, 2013, 05:44:54 pm »
You could buy a house and a car for the price of one of those scopes and probes, but you are paying for the fairy dust with probes as I have just found out, I bought an Agilent 150MHZ probe on ebay and am having the devil of a job to match it to my scope (Iwatsu 40MHZ @25pf) the agilent probe is only 15pf, so far I have it right at 1KHZ but at 1MHZ its shit.
« Last Edit: August 06, 2013, 09:03:59 pm by G7PSK »
alm
  • Guest
« Reply #31 on: August 07, 2013, 09:21:56 am »
So how is it the fault of the probe that you used it on a scope from a different manufacturer and failed to check the compensation range? It's not like Agilent hides the compensation range. A probe with a larger compensation range would have inferior performance (higher circuit loading) on the scopes it was designed for.
Offline G7PSK
« Reply #32 on: August 07, 2013, 12:10:01 pm »
Its not the probes fault, I am trying to make the probe match by changing the compensation network in the BNC, and its not as straightforward as I had hoped and I am having to try different capacitors as none of the equipment I have will actually measure capacitance that low. I am also pointing out tha I understand why this stuff can be so expensive due to a very little personal experience. |O
« Last Edit: August 07, 2013, 12:13:40 pm by G7PSK »
