Author Topic: Fluke 23 Series II or HP E2378A - witch one should i get ?  (Read 5168 times)
Offline bingo600Topic starter
« on: August 05, 2013, 04:46:52 pm »
Guyzz
My brother got 2 working meters for free
Fluke 23 Series II
HP E2378A
He would only use it to measure 230v present or if a wire is broken in a lamp.
He insists that i get the better one , but what should i chose.
I lean towards the HP , but have absolutely no idea about the specs or performance yet .....
I have some neat bench meters , so i'm already covered pretty well.
But if he insists ....  :-+
Hmm seems like the 23 is a 77 (with a yellow case)  ... not a bad meter if i remember correctly.
The HP can do temp' C , but what probe , and my 3457 prob does it better  ...
/Bingo
« Last Edit: August 05, 2013, 04:57:52 pm by bingo600 »
Offline ModemHead
  • No user-serviceable parts inside.
    • Mr. ModemHead
Re: Fluke 23 Series II or HP E2378A - witch one should i get ?
« Reply #1 on: August 05, 2013, 06:26:30 pm »
Yes the 23-II is the same as a 77-II except with the yellow case.  I use one quite often as a general-purpose DMM. Beware the yellow cases have a high rate of internal screw post failures from the self-tapping screws. I think the yellow plastic is more brittle than the gray/green.
The HP is a Japanese Yokogawa instrument. From pictures, I think HP may have specified more input protection than a very similar Yoko-branded one that I kludge-repaired some time ago.  IIRC, I tested the temp function with a K-type thermocouple with banana plugs, one that came with a Fluke 179.
I'm sure you'd be served well by either one.  I'm partial to the Fluke myself.
« Reply #2 on: August 05, 2013, 07:06:42 pm »
Thanx MH
I was told that the HP has 100nA LSB , and the Fluke 10uA LSB , else they should be quite equal.
Is the "Off" on the fluke a real Off ? ... Meaning i can expect that it doesn't eat 9v Batts if in Off pos.
The HP has 2 x AAA , witch are cheaper if the Fluke is a Batt eater  ...
If the Fluke Off is a real Off , then i guess i might chose my first Fluke now.
I have a 34401a or 3457 if i need low amps measurements on the bench.
/Bingo
Offline ModemHead
    • Mr. ModemHead
« Reply #3 on: August 05, 2013, 07:30:31 pm »
The 23-II runs Vbat+ through the rotary switch, so it's a "real" Off.
Just checked one here, it draws (average) 252uA in VDC, 273uA in VAC, and 707uA in Ohms w/inputs shorted.
Not what I'd call a battery-eater.  Battery life is spec'ed at 2000 hrs.  That's three zeros. :)
« Reply #4 on: August 05, 2013, 07:47:01 pm »
Thanx MH
You can say welcome to a "soon" fluke owner then  ;)
/Bingo
Offline retiredcaps
« Reply #5 on: August 07, 2013, 06:01:45 am »
The HP is no slouch in the battery department either.  It is rated for 1000 minimum hours using akaline AA batteries.
http://cp.literature.agilent.com/litweb/pdf/E2377-90001.pdf
