Author Topic: Rigol 1102E and Dave's Honor.  (Read 16791 times)
Offline Dark PrognosisTopic starter
« on: October 17, 2013, 04:35:48 pm »
So, I was having this argument with this guy on a review site and he brought up Dave Jones.  He said that this scope really is only a 30 or 40mhz scope due to how it works and the industry knows it and Dave as well.  Is that right?
How can Dave recommend this scope as a 100mhz dual trace scope if it only does 30mhz???  Something smells funny.
« Last Edit: October 17, 2013, 06:40:16 pm by Dark Prognosis »
Offline johansen
Re: Rigol 1102E
« Reply #1 on: October 17, 2013, 06:03:41 pm »
yeah, take a look at this photo
there should be 25 data points per trace per division, instead there is about 10. there's also a slope change once the blue trace gets to 48 volts, it starts climbing slower. it should reach all the way to 60 volts. the hook in the yellow trace should be lined up with the bottom most ring of the blue trace.. which has a real life frequency of 50Mhz.
instead the blue trace is delayed 5ns, and the scope shows that its frequency changes!... which i know is not the case, it should ring down like any other smps.
the only difference between my scope and the 1102E is the memory depth and the screen size.
another issue is crosstalk. note that the blue trace is lifted 1-2 volts while the yellow trace is falling.
but also note that the oscope isn't sure about that so it waits half a division before displaying this "lift"
in real life there is something there.. its on the order of negative 10 milivolts plus the inductance of the current sense resistor.
so you should see a spike on the blue trace on the order of -1 volt for like 5ns, then it should fall to zero, then stabilize at -10mv (these numbers are relative to the voltage drop across rds on before the gate is pulled to zero)
(one half amp of gate drive through a 20mohm resistor with an inductance of say 5nH)
another issue is lack of significant digits on such things as volts rms. (no surprise, 8 bits is only 8 bits.)
so you might see 60 volts rms displayed, or 61.44, or 60, or 61.44.. it doesn't know how to do a true rms over more than one line cycle i guess.. because that should average out to better than 8 bits.
another issue is the fft only calculates what is on the screen, not what is in the memory. the screen being 234 pixels high rather than 256 means that there's data loss somewhere between the 8 bit ADC and the screen. i've verified this by adjusting the signal so it is just barely clipping on the screen, but should still be below 256 bits wide, the fft and the rms measurements displayed will change.
there is also no warning about this data loss.
Offline sync
Re: Rigol 1102E
« Reply #2 on: October 17, 2013, 06:20:38 pm »
Please show us these signals with a good scope.
I doubt that.
Re: Rigol 1102E
« Reply #3 on: October 17, 2013, 06:38:24 pm »
Then how could Dave have recommended this scope so highly for so many years now?
Something smells when Dave highly recommends a 100Mhz scope yet it supposedly only does about 30mhz.
Offline c4757p
  • adieu
Re: Rigol 1102E and Dave's Honor.
« Reply #4 on: October 17, 2013, 06:41:52 pm »
I had an 1102E, before I broke it... :-\ It was definitely a proper 100 MHz scope. This guy is full of bullshit. And no, my Rigol didn't behave like that stinking turd of a Siglent.
Re: Rigol 1102E
« Reply #5 on: October 17, 2013, 06:43:38 pm »
Funny how it is 8bits of resolution while the lowly 8bit Arduino has 10 bits of resolution on the analog pins.
Offline c4757p
  • adieu
« Reply #6 on: October 17, 2013, 06:45:54 pm »
You try to do 10 usable bits at 1 GSa/sec and get back to me.
« Reply #7 on: October 17, 2013, 06:46:31 pm »
Yeah, I think he was shill (was over on Amazon) but when I went to reply to him this morning the thread had been removed (404 error).  So, I have no idea but what the guy was describing was not accurate nor correct.  I called him out on it and he brings up Dave Jones as saying it had these issues and 30mhz was its tops.  I told him I have sub'd to Dave for a long while now and I never heard him say that but I could have missed it as I don't follow these forums as much as I do his videos.
« Reply #8 on: October 17, 2013, 06:47:57 pm »
No thanks I was just saying.  Do any scopes sample at 1gsps, or higher, at more than 8 bits of resolution?  I think I am seeing some of the reasons people say to keep a good analog scope around.
Offline c4757p
  • adieu
« Reply #9 on: October 17, 2013, 06:53:42 pm »
Not many. There are sampling scopes, which capture a repetitive waveform at high speed by taking many captures with a time offset - if I'm reading the specs correctly, the PicoScope 9200 pulls off 16 bits of resolution with an analog BW of 8/12 GHz, so presumably the overall sample rate, once multiple acquisitions are combined, approaches that or beyond. (Note that I have no experience with high speed sampling scopes...) It's also $10k.
Many of the Agilent scopes have a high resolution mode, which is also made by combining multiple captures, and gets you 12 bits.
« Last Edit: October 17, 2013, 06:55:21 pm by c4757p »
« Reply #10 on: October 17, 2013, 06:58:40 pm »
That boggles my mind how you are oversampling to increase the bit depth.  Interesting.
I am saving up for an 1102E then a signal gen then a proper PSU then the 2000 series so sometime in the next three years, lol.
Offline sync
« Reply #11 on: October 17, 2013, 07:47:26 pm »
Dave measured the bandwidth of his hacked  DS1052E. It's a 100MHz scope. Skip to 16:10.
« Last Edit: October 17, 2013, 07:49:16 pm by sync »
Offline skipjackrc4
« Reply #12 on: October 17, 2013, 07:51:45 pm »
Yes, but they're pricey.  The link below is to a LeCroy.  Agilent has some, as well as Yokogawa.  I'm not sure that Tek does.
http://teledynelecroy.com/oscilloscope/oscilloscopeseries.aspx?mseries=422
Offline Stonent
« Reply #13 on: October 17, 2013, 07:56:57 pm »
Maybe those guys are using the scope only on the X1 probe setting and claiming this. If so then yes, it would appear that way, but so would most scopes.  Now if they've been using a nicer Tek or Agilent scope with the expensive probes, those can auto-detect the probe and compensate so they may not be realizing that. (I hope they would)
« Reply #14 on: October 17, 2013, 07:59:44 pm »
I knew this guy was a shill and full of shit as I remember that episode and not once have I heard Dave bad mouth the 1102E (or even the 1052E).  This guy got assed out and decided to try and bully me by throwing Dave Jone's name at me like a prize fighter throws punches.  It didn't work so the last thing he told me (before Amazon removed the threads) was "I will satisfy you childish behavior by saying I am completely wrong."  My childish behavior was calling him telling him that he was wrong and backing it up.
For future reference this joker's name (for any future reviews you might see from him) is Gordy.
« Reply #15 on: October 17, 2013, 08:01:22 pm »
Exactly what I was saying about it not being an issue with just this scope as he directly said.  I told him not to single out this scope for the issues he was mentioning as it was all of them doing it as it was the nature of the beast with sampling etc...
« Reply #16 on: October 17, 2013, 08:06:43 pm »
That thing is a wet dream but I lost it at the starting from price of $14,900 for the 350mhz version.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #17 on: October 17, 2013, 08:08:18 pm »
Just a bit of history;  Dave's posts about Rigol are as early as ~ 2007 but there was a lot of praise for it from others users since, you can find early discussions about this model in the newsgroups, before this forum existed.
http://www.electronicspoint.com/rigol-caught-their-pants-down-ds1052e-oscilloscope-t172654.html
P.S. The newsgroups are notorious for its vitriol and flame wars; you'll get a bit of it from the infamous Paul A.
http://www.electronicspoint.com/emona-rigol-digital-scopes-t135569.html
If you read the long 1052e hacking threads on this forum, there was subsequent testing done by others to reconfirm Dave's impressions.
Best Wishes,
 Saturation
Offline c4757p
  • adieu
« Reply #18 on: October 17, 2013, 08:12:08 pm »
If anybody ever attempts to measure an oscilloscope's bandwidth like this, never, ever ever ever, believe anything else they say about a topic more complicated than a hamburger.
Offline johansen
Re: Rigol 1102E
« Reply #19 on: October 17, 2013, 09:14:07 pm »
I doubt that.
i believe they use the same firmware even!
the difference between the cml and the cnl is a 28$ memory chip.
Offline sync
« Reply #20 on: October 17, 2013, 09:27:27 pm »
We are talking about a Rigol DS1102E.
« Reply #21 on: October 17, 2013, 09:31:05 pm »
And?
Offline EEVblog
Re: Rigol 1102E
« Reply #22 on: October 17, 2013, 09:43:17 pm »
It is a 100MHz (or more) bandwidth scope. Feed in a sine wave until it's 3dB down and measure the frequency yourself.
Re: Rigol 1102E
« Reply #23 on: October 17, 2013, 09:48:41 pm »
Exactly, Dave.  I was taken back when the dude threw your name at me #1 and #2 he knows enough about you, and apparently electronics, yet doesn't know how crap works?  Made me laugh, and sad, all at once.
I still say he was a shill and at least I was able to call him that.  Either he was a shill or completely retarded but he can't be that retarded because he knew your name at least.
Offline johansen
Re: Rigol 1102E
« Reply #24 on: October 17, 2013, 11:17:33 pm »
but that is only true if the front end amplifier doesn't have the uumph to feed the ADC, which is likely true, but somewhat unexpected.
if the processor has to do math on three samples to get a 7 bits out of 8 accurate that's a different issue.. which is what appears to be going on.
