Author Topic: Rigol - Data Acquisition / Switch System ???  (Read 7583 times)
Offline olsennTopic starter
« on: July 28, 2013, 03:29:12 pm »
What the hell are they doing now? Check out the Chinese version of www.rigol.com and look at the "M300"
Offline Carrington
Re: Rigol - Data Acquisition / Switch System ???
« Reply #1 on: July 28, 2013, 03:47:53 pm »
M300  is a modular data acquisition and switch, with up to 10 plug-in modules:
  - 6 ½ digits DMM module.
  - Multiplexer Module.
  - Matrix module.
  - RF multiplexer module.
  - Multifunction module.
Key specs and  features are:
    5-slot LXI mainframe with up to 320 switch channels
    6 ½ digits DMM module can be enabled/disabled in any slots
    Up to 100K buffer readings with time-stamp for the channel scanning
    Different kinds of plug-in modules with built-in signal conditioning for the measurements
    Math statistics
    Supports Multi-frames cascaded
    Friendly User interface with Online help
    Standard SCPI commands
    Powerful PC software and Web Control function
    Multiple languages support
    4.3' LCD color display
    Complete connectivity: USB Device, USB Host, GPIB , LAN(LXI-C), RS232
The truth is that it must be a fancy.
« Last Edit: July 28, 2013, 04:29:42 pm by Carrington »
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
« Reply #2 on: July 28, 2013, 04:33:28 pm »
So other than the DMM, what does the shit do? What is a "matrix module" and what are the functions of a "multifunction module"?
Offline Bored@Work
« Reply #3 on: July 28, 2013, 04:55:11 pm »
It is for adults only who need to acquire lots of data.
If you are not familiar with the terms, well, as I said, this is adult stuff.
Offline Carrington
« Last Edit: July 28, 2013, 06:56:52 pm by Carrington »
Space Weather.
« Reply #6 on: July 28, 2013, 10:07:10 pm »
Adult stuff my ass; I've got more cock than a Smith & Weston! Doesn't give a person automatic knowledge of what functions are meant by "multifunction". So far it just looks to me like a logic analyzer that gives the current state of all bits on a bus.
Offline sub
« Reply #7 on: July 28, 2013, 11:00:15 pm »
It's for automated testing.  The idea is that you can connect fifty test points up to your device and then scan through and measure them all.  I've used one for thermal testing, you can run some wires out of the chamber for each test point and for your thermocouple, connect them all up to the machine. Whenever you want to make a measurement you set the relays appropriately and make the measurement over the LAN.  You can make all of the measurements in a few milliseconds. It's much better than doing it manually unless you're blessed with an LXI-enabled multimeter for every test point in your device.
Offline Bored@Work
« Reply #8 on: July 29, 2013, 05:11:57 am »
Serious dude, if you can't figure it out by looking at the pretty pictures you still need to grow up. It is childish to run around and ask "what does the shit do?" when all you need to do was to look at the pretty pictures for five seconds.
Offline c4757p
  • adieu
« Reply #9 on: July 29, 2013, 05:42:18 am »
To be fair, I think "logic analyzer that gives the current state of all bits on a bus" was not too unreasonable an analysis to make of the pretty pictures if you have no clue what the thing does.
Offline AndersAnd
« Reply #10 on: November 23, 2013, 10:35:35 pm »
Also at Rigol's international site, although there's no link to the M300 page in the menu system.
http://www.rigol.com/prodserv/M300/
For detailed performance parameters and technical specifications, refer to M300 Series Datasheet
I noticed it in the German Rigol distributor Batronix' Rigol product catalog, where they mention it as being released in September 2013: http://www.batronix.com/pdf/Rigol/Rigol-Product-Catalog-Batronix.pdf
« Last Edit: November 23, 2013, 10:38:32 pm by AndersAnd »
Offline Smokey
  • Not An Expert
« Reply #11 on: January 07, 2015, 04:51:29 am »
This thread has been around a while...
Anyone used one of these?
Offline Smokey
  • Not An Expert
« Reply #12 on: January 08, 2015, 01:32:44 am »
Anyone have an opinion on if the Rigol could be a viable alternative to an Agilent (Keysight) or Keithley in this area?
Offline Jurkstas
  • Country: no
« Reply #13 on: June 18, 2018, 04:18:18 pm »
Hi, any new experiences with M300? It has some features I am interested in. It could replace multiple NI and Keysight instruments in my application. It would have to run 24/7 in production for a few years.
« Last Edit: June 18, 2018, 04:19:57 pm by Jurkstas »
