Author Topic: What is This Connector in Lecroy D500PT Probe Tip?  (Read 915 times)
Online Mechatrommer
  • Country: my
  • reassessing directives...
« on: November 22, 2018, 05:16:27 am »
i bought used Lecroy WL600 Active Differential Probe with 6GHz D500PT Head sold as is but claimed to be working. The head's tip is connected through this female connector (attached picture on right side) as you can see one of its 4 internal ring (female center pin) is broken i think i need to find replacement in case this probe's tip is non functional due to this, still waiting the matching oscilloscope to be delivered so in the mean time i have no way to test the connectivity. does anyone know what connector type or name for this? i've included the dimension in case someone knows all possibilities for this mini coax connector type (2mm outer (gnd) ring diameter with excess or protrusion 2.2mm diameter on the end). i googled IPX, U.FL, MMCX and CRC9 but they dont quite match the shape of this connector (with internal female ring spliited into 4) and larger diameter on the end of outer ring. i have male CRC9 i tried to push it in, it can go in but with a little bit force i'm afraid with many times of usage, it may damage the internal and the outer ring as well which is also splitted into 4. anyone?
It's extremely difficult to start life.. one features of nature.. physical laws are mathematical theory of great beauty... You may wonder Why? our knowledge shows that nature is so constructed. We simply have to accept it. One could describe the situation by saying that... (Paul Dirac)
Online Mechatrommer
  • Country: my
Re: What is This Connector in Lecroy D500PT Probe Tip?
« Reply #1 on: November 22, 2018, 06:45:09 am »
well its another blind mate connector, its SMP connector... problem solved.
Offline lukier
    • Homepage
« Reply #2 on: November 22, 2018, 07:20:53 am »
Try SMPM, like 925-127P-51P from Amphenol.
The following users thanked this post: Mechatrommer
Online Mechatrommer
  • Country: my
« Reply #3 on: November 22, 2018, 07:43:14 am »
yes i think SMPM is more acurately as just now i checked SMP dimension is 3+ mm diameter instead of my measured 2mm something. SMPM is the exact dimension. thanks.
