Author Topic: Rigol DHO 914 (all DHO800/900 series) Fan mod  (Read 1057 times)
Offline GadjetTopic starter
    • My Blog
« on: August 26, 2024, 04:39:17 pm »
Just got my Rigol DHO914 and I like it but the fan noise is really getting on my nerves, not specifically how loud it is but the tone of it.
I'm playing with the idea of adding a replacement fan on the rear, a NoctuaNF-B9 Redux-1600, this fan runs slowere and much much quieter but as it larger it moves more air and even mounted on the rear of the case with a 3D printed bracket, the short test I did ran 2 degrees cooler than with the stock fan and I couldn't even hear it.
Now this is a first off proof of concept and needs some more fiddling to get the bracket so it doesn't hit the desk when leaning back and to be able to mount it on the VESA mount but it proves, to me, that the larger slower quieter fan is the way to go.
Does anyone know if there's a 3D model of the rear cover out there?
2351477-0
    • My Blog
Re: Rigol DHO 914 (all DHO800/900 series) Fan mod
« Reply #1 on: August 28, 2024, 10:22:04 am »
Changed the mount and printed it in a closer colour match to the Scope and used a thinner fan (15mm) so it will sit on the bench without resting on the mount.
The finger guard is a work in progress.
The following users thanked this post: Fungus
Offline thm_w
  • Non-expert
    • My Blog
« Reply #3 on: August 29, 2024, 06:27:55 am »
Oh yes, thanks for that link, I tried a flat plate to begin with but wanted to enclose the fan and have a finger guard but what I've found is that if I have a 3D printed finger guard over the fan with a 5mm hexagon pattern it makes the fan more noisy whenever the guard is place over the fan so I've ordered a wire finger guard and I hope that's more quiet.
With the Noctua 12V 92mm fan @ 8V and no finger guard it's virtually silent.
    • My Blog
« Reply #4 on: September 01, 2024, 08:43:32 am »
Offline gregbettec
« Reply #5 on: October 18, 2024, 02:38:54 am »
I have also printed a fan enclosure, although mine is intended for use on a VESA Bracket. It drops my CPU temp from 64c to 51c and I have not opened the case changed the internal fan in any way.
I used a Brateck MABT-LDT73 VESA mount which is happy with the 1.5kg scope, plus a Brateck quick release MABT-XMA-03, which were about AU$40 and AU$15 respectively.
The VESA mount is easily moved around the lab, plus keeps the probes and scope up and away from soldering irons, etc.
The mount also has the scope's power supply and USB hub mounted to it with velcro. I also use a mounted short HDMI extension cord, so no stress is placed upon the PCB mounted connectors on the back of the scope.
I also wanted a way of storing the probes so they were safe and easily accessible.
The probe storage is reversible so it be flush with the front of the scope or set back, as I have.
My USB hub is mount to the front of the VESA arm and connects the WiFi and wireless mouse dongle. This model USB hub has just the right length cord to fit neatly.
(The part codes are used for each of the attached images.)
If anyone is interested in the STL's or Fusion 3D models please reply to this post.
Any suggested improvements are welcome.
« Last Edit: October 27, 2024, 07:00:39 am by gregbettec »
Offline gregbettec
« Reply #6 on: October 18, 2024, 02:42:12 am »
Here's the rest of the images.
