5 $ UART-USB converter and some terminal (Im using Linux with it and without problems). Even if You made wrong settings, You should be able to see early U-boot logs as some bad chars - at least. If not and voltages are ok, then next step will be to heat up all BGA chips with hot air, to the point of melting solder joints, because single bal can be a cause.
And I repeat myself again: If You want to buy new expensive staff, buy it from certified reseller instead of Amazon, Ebay or something like that. It's more expensive, but much less problematic.
