Author Topic: Rigol DHO800 memory depth / bandwidth upgrades and noise level!  (Read 18038 times)
Online Fungus
Re: Rigol DHO800 memory depth is a deal breaker
« Reply #25 on: November 06, 2023, 06:57:04 pm »
The results are in. Here's the RMS noise level of both bandwidth options, with and without bandwidth limiter, nothing connected to the inputs.
There's surprisingly little difference, only about 5%. I repeated it three times just to be sure, I honestly expected more.
« Last Edit: November 06, 2023, 07:18:23 pm by Fungus »
The following users thanked this post: egonotto, Serg65536
Online voltsandjolts
« Reply #26 on: November 06, 2023, 07:01:20 pm »
I see two screenshots, both at 20MHz bandwidth, showing same noise as expected.
When you say 'nothing' on the inputs, do you mean floating inputs, or 50 Ohm terminated inputs?
Online ebastler
« Reply #27 on: November 06, 2023, 07:05:33 pm »
Look at channel 2.  ;)
The following users thanked this post: voltsandjolts
Online Fungus
« Reply #28 on: November 06, 2023, 07:16:03 pm »
There's two channels on each...
Floating inputs.
Offline Serg65536
  • Country: ua
« Reply #29 on: November 06, 2023, 07:17:41 pm »
Yes ADC - duh.  The DST time shift always puts me off.
And I didn't mean to infer the lack of dual ADC's made it unusable, only that sampling rate seems to be an otherwise high priority spec.
I've got you wrong, sorry.
Yes, BW to SR ratio is not good here.
But it's always nice to have the ability to capture a signal with the maximum available BW and full 1.25 GS/s.
IMHO, it's more disappointing to have very high noise due to 8 GS/s ADC, and use an oscilloscope below 100 MHz on daily basics.
Online ebastler
« Reply #30 on: November 06, 2023, 07:33:40 pm »
The lack of difference might be due to the fact that decimated screen data are used for the RMS calculation? (I.e. the decimation acts as another bandpass filter.)
How do the results change if you change the timebase? Also, doesn't the vertical amplification go up to 500 µV/div -- does that change the result?
Online iMo
  • Country: va
« Reply #31 on: November 06, 2023, 07:37:46 pm »
Store the data in the .csv and make the rms calc in the excel, for example.
The 40uV rms noise means aprox 270uVpp - that is what you should see on the screen then..
Also to measure noise with the open inputs is not the best approach, imho.
« Reply #32 on: November 06, 2023, 08:02:05 pm »
Floating inputs are random number generators, use 50 Ohm termination.
Online 2N3055
  • Country: hr
« Reply #33 on: November 06, 2023, 08:17:24 pm »
You cannot measure noise on 1µs/div. You are high-pass filtering low frequencies out. Pretty much all of the 1/f noise which is actually large part of noise in scope amps..
Set scope at 1 ms/div, 1mv/div, and NO 20 MHz BW limiter.
To see what is actual noise with 100 MHz BW.
Then repeat with 20 MHz limit.
And if you look at your stats, you have very large difference between max and min AC RMS value.
This is the point where you reset stats and see again. If you again accumulate have such a large difference between max and min AC RMS something is wrong.
Make sure to put a non shorting cap  (or wrap a piece of aluminium foil over BNC) on input so there is not induced voltage.
Shorting input with 50 Ω is not going to show what noise is with 1MΩ inputs but less, which is not what you going to see with passive probes connected.
Whenever i have shown any data from any scope that is how it's done.
50Ω measurements are separate set of data.
If you still have large excursions in AC RMS, maybe you have some popcorn noise or something.. Or EMC problem.
« Last Edit: November 06, 2023, 08:25:48 pm by 2N3055 »
Dr. Richard W. Hamming
Online 2N3055
  • Country: hr
« Reply #34 on: November 06, 2023, 08:19:27 pm »
[4]: 500 μV/div is a magnification of 1 mV/div setting. For vertical accuracy calculations, use full scale of 8 mV.
Online Fungus
« Reply #35 on: November 06, 2023, 08:34:11 pm »
I did it at 1us/div. because that's what Dave always does it at.  :-//
I was told that 1mV and 500uV were just software expansions of the 2mV range. I can't find it in the dtasheets though. I'm sure  2N3055 will fill us in on the details.
Online 2N3055
  • Country: hr
« Reply #36 on: November 06, 2023, 08:36:37 pm »
See my post above. Copied from the datasheet. I'm too lazy to retype that much. :-DD
Online Fungus
« Reply #37 on: November 06, 2023, 08:41:55 pm »
Ok, it was the bottom two scales on the DHO900, only the bottom scale on the DHO800.
I found it at the bottom of the datasheet:
Online 2N3055
  • Country: hr
« Reply #38 on: November 06, 2023, 08:42:19 pm »
It was not meant to offend you.
I just pointed out the facts. Even 1ms/div is kind of short really.. I would suggest doing it on longer timebases too. Just to see how much low frequency noise is there.
As I said before, much as  I like Dave, he makes mistakes too and is not always doing lots of preparations before doing videos.
The following users thanked this post: Krisztián
Online ebastler
« Reply #39 on: November 06, 2023, 08:44:59 pm »
Ok, so 1 mV/div is the highest "real" amplification. I think the DSO900 has an additional magnified step at the bottom end, 200 uV/div.
If we assume that the scope does its noise calculations from the acquisition buffer (as opposed to the screen data like the DS1054Z), then using the magnified settings should neither improve nor falsify the results.
Online 2N3055
  • Country: hr
« Reply #40 on: November 06, 2023, 08:52:37 pm »
All of the DHO scopes use same front end amp. They all have best 1mV/div. 200 and 500µV/div are software magnifications. 800/900 and 1000/4000...
As as side not these are the covers I use. E-bay few bucks for a few of them..
Online Fungus
« Reply #41 on: November 06, 2023, 09:07:12 pm »
Here's mine:
Online Fungus
« Reply #42 on: November 06, 2023, 09:10:47 pm »
The results are in...
70Mhz full bw: 61.8uV
100Mhz full bw: 64.2uV
70MHz with 20Mhz limit: 56.38uV
100MHz with 20Mhz limit: 56.83uV
Let the arguments begin!
« Last Edit: November 06, 2023, 09:12:35 pm by Fungus »
Online Fungus
« Reply #43 on: November 06, 2023, 09:21:58 pm »
This is all channels at 100MHz bandwidth. CH1 and CH2 have tinfoil, CH3 and CH4 don't.
The winner is: CH3 - no tinfoil!  :popcorn:
I put a 50 Ohm terminator on CH3 and it went down to 38.8uV average.
« Last Edit: November 06, 2023, 09:24:16 pm by Fungus »
Online Martin72
  • Testfield Technician
« Reply #44 on: November 06, 2023, 09:25:27 pm »
Try average for acquisition...
Online ebastler
« Reply #45 on: November 06, 2023, 09:46:13 pm »
Could you also measure the residual offset voltage (V_avg) on each channel? It will enter the V_rms calculation and might have a non-negligible effect. Some of the traces do not look perfectly centered to their respective 0V arrows.
Online Fungus
« Reply #46 on: November 06, 2023, 09:49:06 pm »
I set 32768 averages and it went down into the nV range. Rigol FTW!
« Last Edit: November 06, 2023, 09:52:25 pm by Fungus »
Online Martin72
« Reply #47 on: November 06, 2023, 09:50:31 pm »
@ebastler:
All except channel 3, maybe he had forgotten to make a self-cal after his playaround with the bandwith down/upgrades.
Btw, the title of the topic is somewhat irritating...
Edit:
No wonder, given the number of passes selected.
But then you also have to question the plausibility of the result.
« Last Edit: November 06, 2023, 09:52:53 pm by Martin72 »
Online Fungus
Rigol DHO800 - to hack or not to hack!
« Reply #48 on: November 06, 2023, 09:53:50 pm »
Yeah, I thought that, too. Does it change if somebody changes it?
Edit: Apparently not. Maybe is has to be OP...
« Last Edit: November 06, 2023, 09:57:51 pm by Fungus »
Online 2N3055
  • Country: hr
« Reply #49 on: November 06, 2023, 09:54:58 pm »
These are nicely made  measurements. Now AC RMS is stable and measurements look valid.
Now people can compare to other scopes with same settings..
FUN FACT: RMS measurements (AC+DC and DC only RMS) will work absolutely perfectly even with scope undersampling. They work by integrating (averaging) and if you just take enough samples it will converge to right result. It is valid technique used in many instruments.
