I installed the new Firmware version 1.04. Not only has the firmware changed, but the "build" has also changed which is now "2024/10/30 11:25:15".
Previously my firmware was 1.03 (00.06) and the Build was 2024/08/01 10:15:55.
At the first test the oscilloscope seems improved in many points. It is certainly stable in operation.
The self-calibration function does not seem to have been shortened in its execution time, in fact it lasted over 26 minutes for me (and before, even if I hadn't timed it it seemed to me to be just over 20 minutes). This self-calibration function gave me better centering of the trace at zero level and almost halved noise values.
The FFT seems very good, knowing how to choose all the parameters accurately.
Below is an FFT of the square wave provided by the internal generator at 10KHZ, with 100K acquisition and AVG 8 samples. The result is decidedly good
