Author Topic: Rigol DHO800/900 Oscilloscope Bug Reports + Firmware  (Read 304462 times)
Offline norbert.kiszka
Re: Rigol DHO800/900 Oscilloscope Bug Reports + Firmware
« Reply #750 on: December 15, 2024, 06:42:25 pm »
Since more than 100MHz don't really make sense on a 4 channel scope with 1.25GS/s
You think every owner of a 4 channel scope is using all 4 channels enabled all the time? Probably only two good things on this series are small size and bandwidth hackable even above 1 GHz (with the price of bigger noise).
What do you mean with firmware made from scratch?
https://github.com/norbertkiszka/Orange-Rigol
Offline AndyBig
  • Country: ru
« Reply #751 on: December 15, 2024, 06:56:10 pm »
Currently I have DHO924S and as for now, Im using it with firmware which I personally made from scratch. But at least bode plot doesn't work as it should. Hard to tell how many bugs are fixed and how many are not, because it's a huge number of bugs.
In the readme: "Oscilloscope app is not fully ported (it's not here yet).".
How do you use an oscilloscope with a non-working oscilloscope app? :)
And about the huge number of bugs - this is a strong exaggeration. There are several non-critical bugs like a poorly working Bode (does not apply to 8xx models) and a non-optimal "flat" window for FFT, but this does not prevent you from using the oscilloscope as an oscilloscope. Everything else is not bugs, but rather "this could have been done better, but it's good enough".
« Last Edit: December 15, 2024, 07:09:19 pm by AndyBig »
« Reply #752 on: December 15, 2024, 07:09:25 pm »
I read in the readme: "Oscilloscope app is not fully ported (it's not here yet).".
An oscilloscope that can't work as an oscilloscope? How do you use it then? :)
Im working on it currently.
Rigol didn't sent source codes as they promised, and kernel modules (in binary form) can't be loaded by any other kernel no matter what, but I can recreate working code based on decompiled binaries. Those modules are nothing very big - just a mediators between app and physical IC's.
« Last Edit: December 15, 2024, 07:14:03 pm by norbert.kiszka »
Online shapirus
  • Country: ua
« Reply #753 on: December 15, 2024, 07:22:19 pm »
Of course it does. 250 MHz bandwidth is perfectly usable with one channel active, which is still a valid use case. Remembering the limitations with the sampling rate per channel being halved (and then halved again) when more channes are activated is then becoming the user's responsibility.
Yes sure it would be nice if the scope could apply filtering to limit bandwidth depending on how many channels are active (to avoid erroneous interpolation of undersampled high-frequency signals), but that sounds like asking too much from Rigol. At least everyone can choose their own poison.
Online Fungus
« Reply #754 on: December 16, 2024, 05:40:38 pm »
I had read (in the first weeks of the product's release) that attempts
 were made to unlock the features of the more advanced models.
But in the end I did not understand what is possible and what is not.
You can buy a DHO804 and tell it to be any model in the DHO800/DHO900 range. You get the bandwidth/memory of that model.
The only difference between 800/900 is the connector for the logic analyzer.
« Last Edit: December 16, 2024, 05:43:18 pm by Fungus »
Online Fungus
« Reply #755 on: December 16, 2024, 05:44:17 pm »
Any recent development on such matter in the latest firmware?
Yep, they fixed about half of bugs and added some more.
They fixed all the important bugs.
What bugs did they add?
Online Fungus
« Reply #756 on: December 16, 2024, 05:46:23 pm »
... everyone can choose their own poison.
Yep, and it takes less than ten seconds to switch model/bandwidth.
(I just double-click a .bat file on my PC and it switches it via WiFi)
Offline riscy00
« Reply #757 on: December 17, 2024, 01:33:52 pm »
I have new DHO924S scope and it on 1.02 FW, after playing around FFT, etc and decided to upgrade FW to 1.04 from Rigol website. Following the procedure to upgrade which was done, but Rigol screen stay Rigol, stuck there for infinite period and does not goes to scope app. I have tried power down and power up but no luck.
I'm looking to return it back for the replacement.  Anyone to suggest how to revert back to 1.02, I have no way to get into scope in order to get upgrade window.
« Reply #758 on: December 17, 2024, 01:39:31 pm »
Two possible methods to fix boot problems are with network if it works and with removing SD card (after removing warranty sticker).
Also there is possibility that it wasn't software related, but it happened at a time of fw upgrade - especially if it's practically new (weak quality tests, if any at all).
Offline riscy00
« Reply #759 on: December 17, 2024, 05:16:23 pm »
How to do network, what I need to do and procedure?
« Reply #760 on: December 17, 2024, 05:27:05 pm »
Procedure begins with diagnostics. There is no magic one method for every problem. Also You need some experience with Linux and/or Android - otherwise You can spent months without success.
So I suggest to send it for repair or for money back.
Online Fungus
« Reply #761 on: December 17, 2024, 05:43:40 pm »
Try copying a firmware .GEL file onto a USB stick with name "HDO800_HDO900_Update.GEL" (name much be exact)
Also create a file on the stick called "force_update_sparrow.txt".
Put the 'stick in the 'scope and power it on, leave it for a few minutes.
It should install the firmware and "force_update_sparrow.txt" will disappear from the stick.
Online shapirus
  • Country: ua
« Reply #762 on: December 17, 2024, 06:10:26 pm »
Try to leave it turned on overnight and see if it boots by morning.
Online iMo
  • Country: va
« Reply #763 on: December 17, 2024, 06:48:15 pm »
So, do you expect the group of seven lovely dwarfs appear during the night, they will roll up their sleeves and repair the box??  :D
Dwarf - (in folklore or fantasy literature) a member of a mythical race of short, stocky human like creatures who are generally skilled in mining, metalworking, electronics repair and software debugging..
Offline ebourg
« Reply #764 on: December 17, 2024, 06:51:27 pm »
No he expects the thing blocking the boot sequence to eventually time out.
« Reply #765 on: December 17, 2024, 06:55:43 pm »
Slight chance.
Online shapirus
  • Country: ua
« Reply #766 on: December 17, 2024, 09:43:41 pm »
Maybe. Dwarves or not, but I've seen locked-up boots eventually resolve after a long (hours) wait on my scope.
« Reply #767 on: December 17, 2024, 09:46:52 pm »
Masochistic... Flashing SD card from backups takes 20 minutes with old SD card reader.
Also trying to fix it, gives some fun and knowledge.
« Last Edit: December 17, 2024, 11:43:04 pm by norbert.kiszka »
Online shapirus
  • Country: ua
« Reply #768 on: December 17, 2024, 11:39:42 pm »
This will not necessarily solve the issue. It might, it might not. My memory may be failing me now, but I think I tried that in my case.
As the original poster said, he was considering returning the scope, which implies that removing the SD card is not an option because of the warranty sticker.
Giving it a few hours to see if it eventually boots is a non-destructive operation, so why not.
Online TheoB
« Reply #769 on: December 19, 2024, 07:20:50 pm »
Using the latest firmware 00.01.04. Shows huge jitter when using AC coupling.
AC triggered:
DC triggered:
This is a signal with 18ns rise fall time. Happens on both edges.
Basically AC triggering cannot be used on this scope (depending on your jitter requirement). I will contact my seller, to see if they can forward the bug to Rigol. This should be on their radar as high priority I feel.
Online ebastler
« Reply #770 on: December 19, 2024, 07:30:26 pm »
Sadly, this bug has been known since more than a year ago:
https://www.eevblog.com/forum/testgear/rigol-dho800900-oscilloscope-bug-reports-firmware/msg5193855/#msg5193855
https://www.eevblog.com/forum/testgear/rigol-dho800900-oscilloscope-bug-reports-firmware/msg5193873/#msg5193873
Online TheoB
« Reply #771 on: December 19, 2024, 08:30:13 pm »
Yes same issue. Would be nice if the start topic would maintain a list of known issues. Something similar as for the DS1000Z. I guess Mr. EEVBLOG is not going to do that..
Online iMo
  • Country: va
Online ebastler
« Reply #773 on: December 19, 2024, 11:03:24 pm »
But this guy had none jitter..
https://www.eevblog.com/forum/testgear/rigol-dho800900-oscilloscope-bug-reports-firmware/msg5194833/#msg5194833
Right -- I don't think the thread ever came to a resolution why that might have been the case. Maybe AC and LFR trigger coupling works when the scope remains set to Chinese language? :P
Online iMo
  • Country: va
« Reply #774 on: December 19, 2024, 11:07:41 pm »
He hacked his 804 to 9xx something as there is the LA option, also had 1.02..
Perhaps worth to try that combo as well.. In EN..
