I recently purchased a Rigol DHO814 oscilloscope and tried to connect my HP Z24i as an external monitor. The cable is a HDMI -> DVI for the input on the monitor (no HDMI input on this monitor).
The Rigol scope will not switch on its HDMI output unless I unplug and replug the cable and then everything is fine, but this will eventually ware out the HDMI connector. It would be much better if there is some menu entry by which I can enable the HDMI output, but I cannot find this menu point - maybe you can.
The DVI connector has a full house of pins and is of high quality.
Do you have any suggestions - thanks.
