Author Topic: Fluke PM6304 PM6306 PM9565 - DC measurement option board, project halted.  (Read 5026 times)
Online coromonadalix
Re: Phillips / Fluke PM6304 PM6306 PM9565 - DC measurement option board
« Reply #25 on: October 09, 2019, 09:42:32 am »
I stopped this project, parts are still available if someone wants them ( negotiable ) , costed me 130$ Cad,  ( cant recall, but maybe enough parts for 2 boards or more minus the relays, (have only 2 of them)  not the same foot print for the resistors, i could make a board the same size has the original one,  but moved on to another stuff
The biggest problems was to find the same precision resistors parts, here in Canada, i did not have many choices.
I dont have the pm6304 lcr meter anymore ... i have an Sencore Lc102 instead.
No pcb's where done,   managed to output a gerber file
Highvoltage was kind enough to send / lend me an original board of his 6306 lcr meter,  had put countless hours to patch and fit the parts, it was my first attempt to make a board design.
It was made with easyeda,  im having a hard time to work with this interface. The board routing was a nightmare,  it would not place the parts correctly at the tiime :(
Remove all .txt extensions
Changed the First thread title, project stopped.
« Last Edit: October 09, 2019, 10:05:23 am by coromonadalix »
Offline HighVoltage
Re: Fluke PM6304 PM6306 PM9565 - DC measurement option board, project halted.
« Reply #26 on: October 09, 2019, 02:51:35 pm »
You put a lot of work in to this project!
Online Neomys Sapiens
« Reply #27 on: October 09, 2019, 09:29:45 pm »
That is good to know. I have a PM6304 incoming with a unclear situation regarding the option boards. While it has been stated that the unit is capable of DC measurements, this might well be a excerpt from the manual instead of the actual fit. Depending on what I will find, I might contact you for what you can offer.
Knowing that the Gerber file would be available is the major part.
« Reply #28 on: October 09, 2019, 10:25:12 pm »
In the previous posts  i've put the gerber files,  easyeda  has a partnership with jlcpcb   I think the boards  should cost around 2-3 $ a piece ??   its only a dual layer board.
The pm9565 board costed way more than that at the time  loll     i've read 250$ usd ??
Normally its the 6306 who has this board by default, not the 6304, it was an orderable option.
