Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
B&K Precision 889B vs. Instek LCR-821 ...? LCR/ESR Bench Meter war.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: B&K Precision 889B vs. Instek LCR-821 ...? LCR/ESR Bench Meter war. (Read 2672 times)
JuanPC
Guest
on:
July 11, 2013, 05:13:47 pm »
http://www.testequity.com/products/3058/
Vs.
http://www.testequity.com/products/1060/
200khz, rs232 included, Z/Phase (LCR-821 only).?
Last Edit: July 14, 2013, 10:30:16 pm by JuanPC
Logged
JuanPC
Guest
Re: B&K Precision 889B vs. Instek LCR-821 ...? LCR/ESR Bench Meter war.
Reply #1 on:
July 14, 2013, 04:43:35 pm »
Is the DC capacitor offset/Bias input of the Instek worth $1000usd. more than BK ?
is the variable frequency worth $1000usd. more ?
someone here has them?
Logged
The Electrician
Frequent Contributor
Country:
Reply #2 on:
July 14, 2013, 10:16:37 pm »
The B&K can only measure at 6 discrete frequencies and 3 voltage levels.
The Instek can measure at 504 frequencies from 12 Hz to 200 kHz and at any voltage between 5 mV to 1.275 volts with 5 mV steps. This is very much nicer than the B&K.
However, I saw a new Chinese LCR meter made by Applent:
http://www.applent.com/products/detail.aspx?familyid=lcr&model=AT2816A
It can measure at any frequency between 50 Hz and 200 kHz with 1 millihertz resolution!!! It can set the excitation level to anything between 10 mV and 2 volts with 10 mV steps. And, it's available on eBay:
http://www.ebay.com/itm/NEW-Hot-Product-AT2816A-High-Frequency-50Hz-200kHz-Digital-3-5-LCR-Meter-Tester-/121140175088?pt=LH_DefaultDomain_0&hash=item1c348460f0
for $1823, considerably less than the $2560 for the Instek.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Library
