Author Topic: Rigol DMM DM858 comparison thread  (Read 28675 times)
Offline MarcelMo
Re: Rigol DMM DM858 comparison thread
« Reply #25 on: March 31, 2024, 09:30:38 pm »
Thanks for testing this.  I assume the Front End of a 858 or 858E will be the same. I noticed also some different behavior, depending on how long the DMM is already switched on (=warm).
I my video the turning point of correct DMM reading was about 50 Volt.  But today I have managed to have it even on 60 Volt. >:(  I seems to be, that if you increase the voltage very slowly, you might end up also with those higher DC values.
Also I confirmed that the problem doesn't appear if you already in the 100V setting (no AUTO), then everything works well.
I was just thinking :  As the 100mV and 1V ranges have in the non-AUTO setting an impedance configuration option (via Measure) of 11.2M Ohm or 10G ohm. So I was wondering if this HW design might influence the current DCV Auto problem?
Or may be better: could the Analogue Front End designed in the different way for those small ranges and the overload protection mechanism is not designed correctly for it.  (Just guessing).  It would be not nice if the HW needs to be replaced.
Anyway,  I was hoping that I was the only one with this DCV bug.   ;)  But that is not case....  Again thanks for testing!!
Offline bdunham7
« Reply #26 on: April 01, 2024, 02:20:11 am »
The input impedance cannot be selected in when autoranging is active?  Which impedance is it then at low voltage levels when autoranging?
Online csuhi17
  • Country: hu
« Reply #27 on: April 01, 2024, 04:40:06 am »
It allows you to change it only in the measurement range of 100mV ls 1V, by default 11.2M.
11.2M in auto mode, measured with another multimeter, 10M.
Fnirsi oscilloscope = waste&regret
Online Kleinstein
« Reply #28 on: April 01, 2024, 07:59:11 am »
The problem seems to be the way the 100 mV and 1 V range handle overload. This has 2 problems:
1) the input current gets quite high.  25 mA is really quite a lot and could even cause hardware damage from overheating from long time overload.
2) The meter does not dedect the overload condition and reads a low voltage instead. It thus does not switch to a higher range and autoranging is not working.
Especially the 1st problem is more like a hardware isssue, not so much a thing that should be handled in software. It would only be a wrong configuration (e.g. relay setting) that could be fixed in SW.
So I am afraid a real fix may need a change to the hardware. Normally the protection should be a hardware thing and not rely on the software at all.
Getting 25 mA arelady at a relatively low voltage suggest a protection with a PTC. This could also explain the slow / thermal effect when slowly increasing the voltage even more.
For only 5 digits the simpler resistor chain protection should be sufficient and the PTC part may be there primarily for the resistance measurements.
Having the auto ranging only with the 10 M input impedane mode makes some sense. The 100 mV and 1 V with high impedance modes would likely need an extra relay switching. This complicates the auto ranging.
Online csuhi17
  • Country: hu
« Reply #29 on: April 01, 2024, 08:40:35 am »
I'm testing a little to measure how the voltage measured by Rigol, the voltage added from the power supply, and the current develop.
It seems that even after a few seconds the range of this error decreases.
For me:
At the lowest voltage.
28.90V and 25mA from the power supply
DM858 starts at 1.085V and when I leave it on, it starts to drop rapidly.
At the highest voltage.
32.91V and 33mA from the power supply
The DM858 measures a slowly decreasing voltage from 87.00mV.
If I play with it a lot, the range where it is not good has narrowed.
Good little advertisement. :-+
(from -1000V to 25V) and (from 50V to 1000V) can be used safely, but between 25V and 50V requires extra attention.
Unfortunately, I could only test between -120V and 120V.
Offline JCS666
    • ea1dzl
« Reply #30 on: April 03, 2024, 02:52:38 pm »
More problems, math and auto mode don't work
It also does not maintain date and time after turning off
 |O
Math only work in manual mode not auto!
Yes, it is not a problem, it is a lack
It keeps the date even after I turn it off.
If you mean to set the time to be visible, then restart it and then not see it, then in the settings "Load Last" must be changed to "Last". Unfortunately, the factory settings default to Hide a Display time...
It is a problem when the equipment is connected to the network, the network time predominates and the time zone is fixed in China, it has already been resolved.
Sorry, my English is Google Translate
Offline UFOdriver
  • Country: ua
« Reply #31 on: April 08, 2024, 08:14:24 am »
Has anyone already tested the conversion of DM858E to DM858?
Offline ass20
« Reply #32 on: April 09, 2024, 10:34:10 pm »
Can you send it for me, for testing modification ?
Offline UFOdriver
  • Country: ua
« Reply #33 on: April 19, 2024, 08:33:19 pm »
Not working upgrade from DM858E to DM858
Offline JCS666
    • ea1dzl
« Reply #34 on: August 14, 2024, 07:34:46 pm »
I have bought 2 weeks ago the new Rigol DM858E. I do like it due to the new formfactor - big screen etc.  I tested some functions the last week, but today - accidently - i was playing with my (also) new Power Supply.  What I noticed is that the DMM is not reacting correctly in the DCV 28...50V range. Situation is as follow : DM858E is not connected yet. So it floating in the mV range (AUTO setting). The Power supply is outputting 33Volt. Then I connect the DMM 858E. to the power supply outlet.  The DMM showed still some low values in the mV range and is also drawing 26mA. >:(  Unbelievable.  I made I video about it.  Nothing fancy what I did.  Anyone some experience with this DMM?  See
I have already complained to my supplier - wondering what Rigol will say about it.  Maybe I have no luck and the problem is only on this specific device (or it is a general problem)
The solution is here: https://bit.ly/DM858Solutions
The following users thanked this post: ZhuraYuk
Offline MarcelMo
« Reply #35 on: August 16, 2024, 12:54:03 pm »
Thanks. It is more or less solved - there is still a temperature dependency and the problem might pop-up again - or at least with my DM858 (which is in repair now).
I made an update of the HW failures - where the low impedance topic is the most dangerous one.
https://youtu.be/Zf48CLWF1pA
Offline alicumircea
« Reply #36 on: October 04, 2024, 08:27:14 am »
Sorry for hijacking this thread, but I believe here are persons that know both the dm858 and Agilent 34401a. I am looking into buying a bench top multimeter and initially I was hunting for an Agilent 34401a. I am repairing iPhone boards and I use a multimeter in diode mode for about 90% of the time. I don’t need extreme accuracy, what I need from a dm in diode mode is to beep during probing - a long beep for a short where the reading is below 0.1V and a short beep when the voltage drop is between 0.1V - 1V. Now, I use a Fluke 179 which is perfect for what I’ve described above, BUT…. I am recording YouTube videos with my repairs and I need to display on the screen my DMM readings. Because of this, I moved from the Fluke to a Uni-t 181a that I could write a software for to have it displayed on the screeen. I don’t very much fancy the uni-t as it does not short beep the way I want it.
Both Agilent 34401a and new dmm s like the dm858 have the scpi protocol that I can interface with my software. My question is:
Does anyone know if the Agilent beeps in diode mode as per my requirements?
Also, same question about the dm858 or any of the newer dmm s that I can find as new for a price tag up to 400 eur?
Unfortunately I couldn’t find any info related to this as extremely few are using the diode reading.
Out of the new DMMs I prefere the Rigol due to its form factor, although I am a huge Agilent fan.
I believe the new dmm s are easier to implement in my software. Agilent proves to be a bit more strict with the scpi protocol, for example I have a new Owon P4305 PSU and an old Agilent E3632A. Interfacing Agilent was a struggle compared to the Owon although both use scpi. For example, the Agilent needs to be in remote mode to have a proper output reading which locks the front panel, so to change the voltage for example, need to take it out of remote, adjust from the panel, then place it back to remote.
Offline W4HBM
« Reply #37 on: December 16, 2024, 01:25:42 am »
When conducting a class in EE, especially at the "101" level, the demonstration gear doesn't need to be world-class, just simple enough for young minds to make the connection.
Someone here mentioned to me the phrase "burden voltage." In order to arrive at a greater understanding of the micro world mu use of bullet proof VOM's like the Simpson 260/270 series is a wonderful add-in. The phrase used in the past, when DMM's were becoming popular, was "phantom voltages."
The Rigol 858's display, while being visible to many around the lab bench, still bobbles, while the 270 analog vane just hangs there, (especially in the dB ranges).
What is comforting to know is that Rigol Technical Support will address issues quickly. If their DM858 shows a "legal" amplitude nearing +20dBm and the SpecAn burns up, I know Rigol will go to the "ends of the earth" to make it right, and to discover what the issue truly was.
Of course, having an HDMI port to bring it up on the big screen would be excellent, but at the simple price, the '858 is fine the way it is.
