Author Topic: Rigol DP832  (Read 1794 times)
Online cowasaki
Rigol DP832
« on: July 31, 2018, 08:02:17 am »
Is it still possible to keygen the latest version of the BP832?  I'm thinking of buying a new one....  Also I've gone to the web site and it asks for the serial number, upgrade code and private key.  The first two are easy enough but is the private key easy to locate or do I need to hack into it?
Offline gperoni
Re: Rigol DP832
« Reply #1 on: July 31, 2018, 08:13:15 am »
I was doing this to my unit yesterday... The private key is generated from your sn, I believe. I don't believe the firmware was patched. Also inserting those keys is a pain.
Online cowasaki
Re: Rigol DP832
« Reply #2 on: July 31, 2018, 09:25:47 am »
So all you needed to do was get your serial number and type it into the web site with the code of the additional thing you want and it generates the code you type into your PSU?  How old/what version software/hardware is your's if you don't mind me asking...
Online cowasaki
Re: Rigol DP832
« Reply #3 on: July 31, 2018, 09:48:55 am »
Just found out I can get the 100 off price for the DP832 from Rapid  :)
I'm taking a teaching qualification via UCLAN so I will be a QT and can teach at work......  I've been accepted but enrolment isn't for three weeks.  I'll probably have to wait until then :(
Offline gperoni
Re: Rigol DP832
« Reply #4 on: July 31, 2018, 09:58:49 am »
Mine is a couple of years old, I honestly couldn't even find the firmware version when looking for it yesterday, the menu is that cumbersome. I also plan on replacing the fan on mine because it's so noisy I rarely want to use it.
Offline 1anX
Re: Rigol DP832
« Reply #5 on: July 31, 2018, 10:22:39 am »
This video explains how!
The following users thanked this post: cowasaki
Offline peo007
Re: Rigol DP832
« Reply #6 on: August 03, 2018, 10:36:49 am »
Hello
i try too upgrade my DP832 with Riglol 1.03d but i only get (Installation fails )   :-//
i have try all 5 options
What am i doing wrong?
Boot ver 1.09
Digital ver  00.01.14.00.03
Offline peo007
Re: Rigol DP832
« Reply #7 on: August 06, 2018, 03:58:47 pm »
Answering myself
I let it be on for more than 24h,
Then it worked to feed in the codes   ;D
Online Wolfgang
    • Electronic Projects for Fun
Re: Rigol DP832
« Reply #8 on: September 30, 2018, 12:54:10 pm »
I started an opinion poll about the RIGOLs
https://www.eevblog.com/forum/testgear/what-is-your-opinion-of-the-quality-of-the-rigol-dp832(a)/msg1856247/#top
Please give a rating of your own experiences with this stuff - good or bad, whatever it may be.
Thanks
  Wolfgang
