Author Topic: rigol dp832 acceptable precision  (Read 602 times)
Offline Redeeman
« on: October 07, 2019, 06:33:33 pm »
Hello.
Bought a DP832, and straight out the box, it read 0.01v on channel 1, 0.06v on channel 2, 0.00v on channel 3.
I thought this 0.06v atleast on channel 2 was a bit high off. I suspect even off spec, but certainly if one were to buy the high accuracy option. I tried riglol'ing to unlock high accuracy, but i couldnt get it to work, so I just went straight to the hack to "convert" it to a DP832A. Worked great, easily.
now it says 0.005v on channel 1, 0.016v on channel 2, and 0.000v on channel 3.
thats a bit strange, the rounding has then been quite off on channel 2?
this offset seems to follow in the readout no matter where in the 0-32v range I set.
What are your thoughts on this?
Offline Grandchuck
Re: rigol dp832 acceptable precision
« Reply #1 on: October 07, 2019, 06:59:28 pm »
Mine (DP832 ... unhacked) gives:
On channel 1, -4 mV
On channel 2, 0.5 mV
On channel 3, 0.1 mV
Offline maginnovision
« Reply #2 on: October 07, 2019, 07:56:48 pm »
Just calibrate it then and call it a day.
On channel 1, -4 mV
How is your unhacked unit giving you microvolts for readback?
Offline Grandchuck
« Reply #3 on: October 07, 2019, 07:58:45 pm »
The reported readings were produced using a separate DMM.
