Author Topic: Rigol DP832 Dial Sensitivity  (Read 687 times)
Offline eev_carl
« on: January 26, 2019, 02:46:07 am »
When I adjust the voltage with the dial on the DP832, it goes up by millivolts.  Any way to make this go up and down by volts?
Thanks,
Carl
Online JDubU
Re: Rigol DP832 Dial Sensitivity
« Reply #1 on: January 26, 2019, 04:18:53 am »
Use the left and right arrow buttons (on each side of the dial) to select the digit that you want the dial to increment/decrement.
The following users thanked this post: eev_carl
Offline eev_carl
« Reply #2 on: January 26, 2019, 04:21:58 am »
Perfect! thanks
