I was looking at a used DP832 which is claimed to be lightly used and purchased new about 3 years ago. Is there any way to identify if it is a newer version with the revised heatsink? The serial number is visible in the listing...
Otherwise I saw mention of the heatisink being visible from outside (through the vent)? Is there an easy way to determine this based on a photo of this vent? (Heatsink color for example?)
Also, I have seen that there may have been some added caps to fix the noisy 4.2V rail on the back of the control board. Is it known whether these fixes were implemented at the same time as the heatsink change?
