Author Topic: Rigol DP832A or Instek GPP-4323?  (Read 1665 times)
Offline rbooth84
« on: February 10, 2020, 01:21:00 am »
I'm torn between getting the Rigol DP832A or Instek GPP-4323 with the LAN Option. I can find all kinds of information on the Rigol DP832A but the Instek GPP-4323 seems to be lacking a lot of reviews.
Is the GPP-4323 worth getting over a DP832A?
Offline maginnovision
Re: Rigol DP832A or Instek GPP-4323?
« Reply #1 on: February 10, 2020, 03:03:03 am »
Looking at the GPP series I'd PERSONALLY go for the 3323 over the 4323. The third channel is only a selectable voltage but it offers up to 5V/5A and has a USB output for the channel. As someone who routinely uses a USB adapter on my supplies I think that's great. Also you just buy the DP832 and unlock all the options. If you want the silly UI you can add that too.
Offline nctnico
« Reply #2 on: February 10, 2020, 10:25:11 am »
Spec & feature wise (it is also a DC load) I'd go for the Instek but I have no hands-on experience with it. I disagree with maginnovision on the GPP4323; I think this is the best choice. The 3323 has a fixed output channel which isn't current limited. The GPP4323 has 4 channels with variable voltage and adjustable current limiting. All the models have a USB port which you can use as a fixed 5V power supply if you want to.
« Last Edit: February 10, 2020, 11:17:58 am by nctnico »
Offline rbooth84
« Reply #3 on: February 10, 2020, 01:59:41 pm »
From everything I’m reading the GPP-4323 is better feature wise against the DP832. I will get that ordered this week.
Offline Gandalf_Sr
« Reply #4 on: February 10, 2020, 02:07:41 pm »
You could buy a DP832 and then use a 'magic' USB stick to convert it to a DP832A.
If at first you don't succeed, get a bigger hammer
Offline nctnico
« Reply #5 on: February 10, 2020, 02:56:24 pm »
Still the GW Instek GPP-4323 offers a whole lot more bang-per-buck compared to the DP832. The price difference isn't that big anyway.
« Reply #6 on: February 10, 2020, 04:17:01 pm »
I didn't look closely enough to see that it is only limited at 5A for 3rd channel. That can be a downside for some but for my specific use case I'd end up having to put 3/4 in series at 5V to get the current I need, and even then it could occasionally hit the current limit which is no good. That's just for me though, as this wouldn't be a primary lab supply for me.
After you use it some let us know what you think.
Offline rbooth84
« Reply #7 on: February 10, 2020, 04:42:42 pm »
What would you use as a primary lab supply?
« Reply #8 on: February 10, 2020, 05:40:21 pm »
Where I diagnose and develop I use the Rigol DP832 with the Siglent SPD3303X as a standby and vref supply. Where I repair and build I use two R&S single channel supplies.
