Author Topic: Rigol DP932U Unlocking  (Read 9395 times)
Offline bigfedeTopic starter
  • Electronic Automotive Engineer @ Bitron
« on: November 07, 2022, 05:42:07 pm »
Hello everyone. Is there any possibility to unlock all features of the Rigol DP932U?
Offline ozkarah
  • Country: tr
Re: Rigol DP932U Unlocking
« Reply #1 on: November 21, 2022, 02:49:19 pm »
The following message explains how to upgrade/hack the Rigol DP800 series, DL3000 series, and DG1000Z series.
https://www.eevblog.com/forum/testgear/need-help-hacking-dp832-for-multicolour-option/msg4028779/#msg4028779
May be same procedure applies to the DP932U. To understand if the keys work you can try just first two steps (which enables LAN option permanently).
If those steps work there is a big chance that the rest of the procedure also will.
I am writing down those steps also here:
1- Go to: http://gotroot.ca/rigol/riglol/. Enter your power supply's serial number in the Serial box. Enter "F6LT" in the Options box. Click Generate.
2- On your power supply, go to: Utility → Option → Install. Enter the code generated in the previous step, and press OK. The LAN option should say "Official". Turn off the power supply.
3- Turn on and check options if the LAN option is enabled.
The following users thanked this post: thm_w, radensb
« Reply #2 on: January 16, 2023, 12:31:44 pm »
Thanks, I will let you know shortly if the procedure works.
The following users thanked this post: ozkarah
Offline zsolttailor94
  • Country: hu
« Reply #3 on: January 18, 2023, 07:26:41 pm »
Hello bigfede!
Any update on this topic? I just ordering mine..
Thank you very much for your feedback! :)
« Reply #4 on: January 19, 2023, 08:01:37 am »
Hello!
Unfortunately I'm in italy and I have ordered mine before Christmas but apparently due to shortage is not still available. Yesterday I have talked with the distributor that said that will arrive next week. Fingers crossed.
Hello bigfede!
Maybe if your arrive earlier than mine (hope so) let us know if the procedure is valid.
  • Country: hu
« Reply #5 on: January 19, 2023, 06:15:07 pm »
Hello!
Thanks for the update! Sure, if I got mine before you I will try it out and let you know!  :)
« Reply #6 on: January 24, 2023, 03:20:14 pm »
Hello!
Mine not arrived yet :-- how about yours?
  • Country: hu
« Reply #7 on: January 24, 2023, 08:28:47 pm »
Sadly mine neither. Now for almost 1 week at the DPD guys.. :/
Maybe tomorrow! (I hope) :)
  • Country: hu
« Reply #8 on: January 25, 2023, 10:15:13 pm »
Finally mine arrived today, for the first sight no success, I even can't find any option to put in activation key manually (like it was the case with the 800 series), maybe it can be done with USB method. The mentioned site for me somehow does not work, it won't fill out the privatekey field and without it the site won't generate..
The USB method is available here: https://www.eevblog.com/forum/testgear/need-help-hacking-dp832-for-multicolour-option/msg4028779/#msg4028779
But I have not tried it yet. (One guy was trying with the E model but with no luck :( ) If I have any updates I will let you know.
If you have anything, please share it! :)
Have a nice day!
Offline ozkarah
  • Country: tr
« Reply #9 on: January 31, 2023, 12:35:08 am »
I guess you should try 5.A step.
Offline dhyddr
  • Country: cn
« Reply #10 on: January 31, 2023, 05:55:25 am »
The DP900 and DP2000 series system is different from DP800 series It have touch screen
The DP800 method can not be use
I think the method mostly like HDO series you need a key.data to hack it
« Reply #11 on: February 01, 2023, 02:45:55 pm »
Mine have arrived. Need couple of days to collect it as have been delivered to a different address|  |O
Once unpacked first thing is understand how hack it, stay tuned! :-+
« Reply #12 on: February 09, 2023, 07:46:40 am »
Finally arrived and at my bench. It seems that the three is no way to get into. SSH is open but the password is unknown.
From a firmware update I only can retrieve the root password hash that is: "$1$AyZFfkd2$alU/zJwFZPKfo387Yc68X0"
Port 55555 is closed.
Offline Xoff
« Reply #13 on: February 11, 2023, 12:59:59 am »
To communicate with DP932 over the LAN, use port 5025 (instead of 5555).
« Reply #14 on: February 13, 2023, 11:32:19 am »
Yes, I can open the connection. Any suggestion for command to be sent?
« Reply #15 on: February 16, 2023, 08:45:27 am »
For the moment no news :( I'm not still able to get into it.
Offline NAC
  • Country: cn
« Reply #16 on: February 20, 2023, 07:35:09 am »
Hi, i am ready to get one, but not sure 932U is abled to hack. is there any progress on the issue? thank you everyone。
(hope my poor english won't trouble you)
Not A Contributor...
« Reply #17 on: February 20, 2023, 08:36:34 am »
Currently I'm not able to hack it. SSH is open but the password is still unknown. I've tried to send command via telnet (to change the model from DP932U to DP932A), the command seems to be correctly recognised but the model is not update.
The following users thanked this post: NAC
Offline NAC
  • Country: cn
« Reply #18 on: February 21, 2023, 04:23:24 am »
May success wait upon your efforts!
« Reply #19 on: February 21, 2023, 12:31:31 pm »
It will be very helpful if someone can help me!  |O
Offline coromonadalix
« Reply #20 on: February 21, 2023, 12:44:01 pm »
Be patient ...
« Reply #21 on: February 22, 2023, 07:51:46 am »
I'm famous to be patient!  ;D
Offline llg
« Reply #22 on: March 12, 2023, 07:59:17 pm »
Pwd iz: Rigol001
« Reply #23 on: March 12, 2023, 09:25:03 pm »
Pwd iz: Rigol001
Yes it works. Now I need to fine the Key inside the filesystem.
« Reply #24 on: March 13, 2023, 07:52:43 am »
Well, it seems more difficult than expected. It's not present inside the filesystem the famous Key.data. I suspect that these files are located inside a partition that I can't mount.
Any idea? Main application is inside a partition mapped into "/mnt/app". I've attached the list of files.
Offline DavidKo
  • Country: cz
« Reply #25 on: March 13, 2023, 10:57:40 am »
Than is odd with root rights you should be able to mount anything, you only need to know device name and mount point (you can may need to create one)
to see all mounted partitions simply run "mount"
to see automatically mounted partitions "cat /etc/fstab" - may be a different path if they have modified standard distribution
« Reply #26 on: March 13, 2023, 11:29:34 am »
Sure I can mount whatever I want but the command mount need the filesystem type and I'm not sure about that.
Offline tv84
  • Country: pt
« Reply #27 on: March 13, 2023, 02:20:15 pm »
The "Key.data" should be the "PubKey.LIC" in your 2nd image...
I've never looked into this device so it's just an educated guess.
« Reply #28 on: March 13, 2023, 02:47:19 pm »
This is what I thought. But it's in a different format, it's ASCII.
Offline tv84
  • Country: pt
« Reply #29 on: March 13, 2023, 04:03:34 pm »
So, it's in plaintext. It doesn't matter the format. The important is the contents and to know how it's used.
« Reply #30 on: March 13, 2023, 04:12:49 pm »
I've tried to use this key and created the attached file but the go program is not working. It generates correctly the keys but they not work.
Offline tv84
  • Country: pt
« Reply #31 on: March 13, 2023, 04:43:04 pm »
1. The DP932U is also Android?
2. Why are you assuming that the DP has the same licensing implementation error as the HD scope?
3. This is a pubkey. You'll never be able to license it with the specific stock key. Or did you replace it?
4.  If you did replace it, did you change it in the FRAM or it doesn't get stored there also?
« Reply #32 on: March 13, 2023, 04:50:13 pm »
1) No it's openwrt (TinaLinux)
2) Not quite sure I've understand. I've seen in the Rigol website it's possible to buy these three licenses: HIRES, ARP, DIGITALIO.
3) No I haven't. I have not enough knowledge on this system and how these key works to generate a serial.
Please if you know something more I will be pleased to learn how it works. We can modify the go script to generate this serials as well.
Offline tv84
  • Country: pt
« Reply #33 on: March 13, 2023, 05:06:36 pm »
As I've told you, never looked into this. Nonetheless, this should be closer to the MSO5000 than the DHO so the go script is not enough.
« Reply #34 on: March 13, 2023, 05:11:00 pm »
Ok so what can we do to start?
Offline Userli
« Reply #35 on: July 01, 2023, 04:11:07 pm »
For DP932E  changing
00 30 a0 e3 08 30 0b e5 76 to 03 30 a0 e3 08 30 0b e5 76
and for DP932U
01 30 a0 e3 08 30 0b e5 6a to  03 30 a0 e3 08 30 0b e5 6a
will bring the device into an identity crisis.
« Last Edit: July 01, 2023, 05:23:18 pm by Userli »
« Reply #36 on: July 03, 2023, 09:18:17 am »
For DP932E  changing
and for DP932U
Sorry man, I didn't understand what change where.
Offline ashik
« Reply #37 on: January 05, 2024, 03:12:37 pm »
Any updates on unlocking the DP932 series? I just ordered the DP932E and wanted to know if its hackable. Thanks in advance.
Offline sensille
« Reply #38 on: January 05, 2024, 07:49:27 pm »
See https://www.eevblog.com/forum/testgear/rigol-dp900-dp2000-series-hack
All is well :)
The following users thanked this post: ashik
Offline ashik
« Reply #39 on: January 06, 2024, 05:29:54 am »
Thanks!!
