I currently own a Tektronix 2465B and a 2467B. ....
.. I wanted to buy my first digital oscilloscope.
Anxious for your opinions.
Well, correct me if I'm wrong, reading above points, I guess you never really realized the true power of DSO which the single shot capture.
This alone sometimes will make even the really good analog scope simply loose it's value against a cheap DSO, especially in a situation where you have to catch a non repetitive glitches.
I'm not an expert, but I sort of understand as I own similar setup with yours on analog side, and currently with these below combination
, these both duo are very-very effective and have a really great value when it comes to probing using scopes, imho. (PS : Just ignore the DS1104Z, as its very similar to a "hacked" DS1054Z, or any other "relatively" cheap DSO)
My point is, a good analog + a "relatively" cheap but
new DSO offer much more value for the money.
My 1/4 watt resistors worth.
