beta-path rigol DS1000Z firmware (2017) and plugin library.
changes:
1) Ext port 6000 funcs - read/write/call (see rigolif programm)
2) pluses -> pulses
3) rnage -> range (decoder:conf:range)
4) Change USB Buffer Size (40->200) - test, please. I don't use USB IF
5) Disable set bandwidth to license maximum on start (BW20 fix)
directory:
rigolif           sample programm for 6000/UDP
add_info          mixed info
libb              plugin library
patch             port 6000/UDP patch sources
plugin_simple     sample of simple plugin (single LED cycle and exit)
plugin_thread     plugin with thread (permanent LED cycle)
!!!WARNING!!!
This is Beta version.
AS IS, AS IS, AS IS.....
konnor, 30.03.2018
