Author Topic: Rigol DS1000Z - firmware patch & plugins  (Read 68844 times)
Offline valcher
  • Country: ru
Re: Rigol DS1000Z - firmware patch & plugins
« Reply #125 on: January 23, 2022, 06:23:53 pm »
Hello!
Sorry, I don't know if I chose the right topic, but I need help or advice.
When updating the firmware on the Rigol DS1102Z-E, the power was accidentally lost. Now, after turning on, the RIGOL splash screen appears, the button backlights turn on one by one, but then everything stops. How can I resurrect the oscilloscope, what should I do?
Offline valcher
  • Country: ru
« Reply #126 on: January 25, 2022, 08:48:52 pm »
I solved the problem thanks to this post - https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/msg3608676/#msg3608676
Everything has been restored to its best.
Thanks to the forum.   :)
The following users thanked this post: Fungus, trmntr
Offline jhaled
  • Country: co
« Reply #127 on: January 25, 2025, 10:14:47 pm »
Please add also the copying of the GEL file in the NAND, since it may/usually contain the bootloader. That makes available the GELs with bootloaders that are not public.
This does not make sense, since the bootloader must be in spi-nvram (the processor is loaded from there). You just need to cut off the tail of the DS1KZ_NVRAM.BIN.
Everyone can brick their devices now...  :) The only thing missing is a tutorial to start from scratch with a full-erased device.
It's simple ;D
1) Open device
2) Write a file DS1KZ_NVRAM.BIN to W25X40 (by jtag, by external programmer or any other method)
3) Insert USB Flash with gel and  power on
where can i get that file DS1KZ_NVRAM.BIN
