Author Topic: Rigol DS1000Z series buglist continued (from: 00.04.04.03.02)  (Read 54503 times)
Offline JohnPi
Re: Rigol DS1000Z series buglist continued (from: 00.04.04.03.02)
« Reply #325 on: September 03, 2018, 10:36:03 pm »
I looked through that code (I don't have a convenient system to build/run it on)-- it appears to download either 1200 or 250000 bytes. My problem is when downloading 8244+n*64 only -- 250000 is not an issue in that.
My problem arose when I was specifically downloading different lengths in the range below 30000; it arose from old habits of being frugal with memory. I changed my own code to download 8000 byte chunks, but I guess I could just download a single 30000 byte block and truncate it.
In the end, I don't know if this ia Rigol or a pyvisa bug.
p.s. I updated my example above to select the USB instrument more easily.
Offline MarkF
« Reply #326 on: September 03, 2018, 10:54:33 pm »
It looks like you're trying to use a USB connection?
I don't know if it will have any effect.  But, you could try changing the OS low level receive buffer size.  The default size for a LAN connection would be different than a USB connection.
Offline JohnPi
« Reply #327 on: September 04, 2018, 02:19:50 am »
@PeDre - thanks for checking. I see it works for you at 8244. What is that program you used ?
When I run my pyvisa program with different values for chunk_size:
DS1054Z = GPIB.open_resource([_ for _ in GPIB_Resources if re.search('^USB.*:DS.*INSTR$', _)][0],chunk_size=3000)
it doesn't appear to fail as often, but there are definite slow downs at some points (watch the results scroll by) -- they appear to be at 64-count intervals. In my case, starting at 8200:
for NPOINTS in range(8200,30100):# fails at 8244 first
gives a slowdown (but not a fail) at 8226.
3.6.5 |Anaconda, Inc.| (default, Mar 29 2018, 13:32:41) [MSC v.1900 64 bit (AMD64)]
visa 1.9.1
Offline JohnPi
« Reply #328 on: September 04, 2018, 02:42:22 am »
Yes, USB. I have tried with the LAN with longer lengths with no problems. I haven't tried this code over the LAN -- will do (it appears you have to reboot the scope to switch from USB to LAN).
-- update: - I can't get my pyvisa to work over the LAN. Anyone know the magic resource name ? IP = 10.1.0.54, port = 5555
GPIB = visa.ResourceManager()
DS1054Z = GPIB.open_resource('TCPIP0::10.1.0.54::5555::INSTR')
print("DS1054Z:", DS1054Z.query("*IDN?"))
fails
Don't know how to change the OS buffer size. There is a chunk_size option in pyvisa which has an impact -- it moves the starting point of the issue around, but doesn't eliminate the issue.
« Last Edit: September 04, 2018, 03:17:03 am by JohnPi »
Offline Hauke
« Reply #329 on: December 30, 2018, 06:15:48 am »
Hi all,
for me the password login rigollan/111111 or test/111111 never worked, and since the headline post of this thread states that this problem should be gone with the current firmware version, I updated and tried again; no success. But this finally worked for me:
  • Connect to the scope via http://[IP-Address]
  • Select "Security"
  • Enter as old password: 111111
  • Enter as new password again: 111111 (twice)
  • Confirm --> Success message
  • log in with any username with four or less letters, pw 111111 --> Works!
So I used as username test, blah, 1234, a - all worked. 12345 or rigollan or rigolan did not work.
No idea why my scope behaves differently as others, but from the forum I find others that used test and blah also successfully.
Whatever - /me is happy now.
Cheers
Hauke
Offline ankerwolf
  • Country: at
« Reply #330 on: January 02, 2019, 02:39:47 am »
Hello,
I posted sometimes:
With the last Version 00.04.04.03.05 the login is now working with:
username: rigolan
password: 111111
LG Wolfgang
Offline Hauke
« Reply #331 on: January 05, 2019, 05:17:15 am »
Hi Wolfgang,
sorry to say: But not for me. It is as I write: any four letter (or shorter) username works, anything 5 digits plus: No success.
Or are we talking about different logins? I refer to accessing http://[IP of the scope]/, and then hitting "Network settings". Where do you refer to?
Cheers
Hauke
