Well, I should have upped the ante on the GAS years ago
U1273AX has a broken screen which thankfully can be used with the bluetooth thing and yeah it works
my other UT61E i sold it to my friend and he promptly blew the current traces up because he's an idiot
UT61E's NOT the kind of meter for crazy current possible scenarios the fuse AND trace goes bang (he placed it in current mode across a escooter's battery)
and then my UT61E popped after i guess 7 years? I used it fine and then now it went from slow turn on to only turning on for a split second when I detach the battery
Tried everything, contact switch, cleaning zebra strip, checking battery contact, changing batteries and I'm not too fussed on searching for dead components, I don't have the time.
Yikes. Not too bad but i didn't really use it much until a year ago anyway
As I quote photoninduction " I POPPED IT!! "
So, what do I buy now to replace it. Maybe i don't need 20k but I probably prefer it to be around 6000 resolution with passable input protection like the uni-t. don't need to be absolutely overkill for poking around with low energy situations. Oh preferably about the same price as well
Saw the anengs and its oems, not sure about its resilience. I had a mastech, sold it off because their displays are butt. Maybe another UT61E?
