Author Topic: Rigol DS1000Z Series Latest Firmware - "Pluses" Spelling Error Corrected  (Read 2271 times)
Offline Jon WilderTopic starter
I just updated my DS1054Z to the latest firmware last night (v00.04.04.SP4 at the time of this writing) as I had not done it since I first purchased it in early July 2016. The "Pluses" spelling error appears to be corrected on this version.
« Last Edit: December 21, 2019, 02:46:47 pm by Jon Wilder »
The following users thanked this post: Mechatrommer, edavid
Offline bingo600
Re: Rigol DS1000Z Series Latest Firmware - "Pluses" Spelling Error Corrected
« Reply #1 on: December 22, 2019, 09:38:16 am »
Any url for dl ?
I have an ooold 1054Z (4+ years) w. original fw , that might need a fw upgrade.
Can i do the upgrade in 1 step , or does one have to "land" on a specific middle version , in order to Ie. upgrade the loader before going to latest ??
/Bingo
Offline Terry01
  • Country: scotland
« Reply #2 on: December 22, 2019, 11:47:53 am »
I have 1 too that is around 2 years old, I am sure! I have never updated it although I have threatened to on a few occasions. It is something I need to do so I might just do it over the weekend and that will be it done. Is it still the same process as described on the 1054z update thread on this forum?
Thanks
Sparks and Smoke means i'm nearly there!
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: December 22, 2019, 11:52:22 am »
now they want to register...
https://int.rigol.com/SUPPORTS/software-firmware-download_3.html
their rigolna web doesnt need registrament but took ages and keep cutting download line...
https://www.rigolna.com/firmware/
i believe you can directly upgrade from ver1 to this ver4 directly, no need intermediate upgrade. btw, pulses on the left side menu was fixed by earlier version, its just pluses on the measurement output at the bottom screen that was not.
Offline Terry01
  • Country: scotland
« Reply #4 on: December 22, 2019, 11:58:58 am »
Cool!
Online Fungus
« Reply #5 on: December 22, 2019, 03:14:31 pm »
They always wanted that, but there's no confirmation emails or anything. You can type in rubbish and you'll get to the download page.
  • Country: my
« Reply #6 on: December 22, 2019, 03:47:41 pm »
they have verification code sent to email to pass registration.. this is the first time i have to register, 2 or 3 downloads of previous version didnt require registration... anyway it doesnt hurt..
Offline bingo600
« Reply #7 on: December 22, 2019, 07:52:09 pm »
I just upgraded to the latest
Pre update
894776-0
Post update
894780-1
I have seen some nice system info images w. bootloader & cpld version , mine is quite sparse
Is that because i have an ancient bootloader , or don't i do the correct show command ??
I used <System> - <Show version> , i think it was called
Ahh  :palm:
https://rigol.desk.com/customer/en/portal/articles/2286510-how-to-check-the-full-firmware-and-hardware-revision-on-a-ds1000z-oscilloscope
Power on the oscilloscope.
Under the Trigger area on the front panel, press (Quickly) Menu > Menu > Force > Menu
and then press Utility > System > System Info
Hmmm ... That still just shows the short version of system info :-//
/Bingo
« Last Edit: December 22, 2019, 08:17:36 pm by bingo600 »
Online ebastler
« Reply #8 on: December 22, 2019, 08:11:03 pm »
Under the Trigger area on the front panel, press Menu > Menu > Force > Menu and then press Utility > System > System Info
You have to press the "Menu - Menu - Force - Menu" sequence reasonably quickly.
Also, make sure to use the "Menu" button in the Trigger section, not the one in the Horizontal section.
Offline bingo600
« Reply #9 on: December 22, 2019, 08:12:11 pm »
@ebastler
Thanx  :-+
Just got it working
894794-0
/Bingo
« Last Edit: December 22, 2019, 08:16:21 pm by bingo600 »
Offline BravoV
  • +++ ATH1
« Reply #10 on: December 22, 2019, 08:22:12 pm »
Startup counter : 31 ...  :o
Offline bingo600
« Reply #11 on: December 22, 2019, 08:31:30 pm »
I'm using my TEK and a Logic Analyzer more  :-DD
/Bingo
Offline montemcguire
« Reply #12 on: December 22, 2019, 09:58:31 pm »
I have an HP 54720D with 332 power cycles, but 95700 hours on-time, which is equivalent to almost 11 years! The previous owner (NASA) apparently didn't like to shut it down often.
Online tv84
  • Country: pt
« Reply #13 on: December 22, 2019, 10:39:15 pm »
 :wtf:: Was it taken from the Space Station? ?
Offline rstofer
« Reply #14 on: December 23, 2019, 12:28:19 am »
After the upgrade and reboot you should probably do a Self Calibration - Utility -> 2d Page -> Self Cal
You should allow the scope to come up to temperature - about 1/2 hour according to the manual
Don't forget to remove the probes - although, the scope will remind you, it's hard to overlook
« Last Edit: December 23, 2019, 12:49:38 am by rstofer »
Offline bingo600
« Reply #15 on: December 23, 2019, 03:35:38 pm »
I did remember to do a CAL  :-+ ... Took forever +1
/Bingo
