Author Topic: Rigol DS1054 is a champion  (Read 12571 times)
Offline TK
Re: Rigol DS1054 is a champion
« Reply #25 on: June 17, 2017, 12:14:57 am »
I'm guessing all the ringing is just from the probing method used? I'd be a little concerned seeing 0.5V of noise on a 3.3V signal.
Still glad to see that even with a high sampling rate, analog bandwidth will still bite me in the backside.
You are correct, I am using breadboard and standard ground loop
Offline TK
« Reply #26 on: June 17, 2017, 12:16:28 am »
Keysight EDUX1002G modded to DSOX1102G.  2GSa/s 100MHz 2+1 channel.
« Last Edit: June 17, 2017, 12:18:14 am by TK »
The following users thanked this post: Fungus
Offline ebclrTopic starter
« Reply #27 on: June 18, 2017, 09:09:33 am »
It's interesting that in the Rigol, you can see the counting transactions ( Channel 2 blue ) and in Keysight you see a freeze counting value Showing that only 1 waveform is acquired while on Rigol was many, I guess was 32 since you can see a transition on 5 bit
I guess you use a too long GND path, try remake  with all probes GND connect to the GND pin near the 0 button or right near PIN 21, there is a better and short GND who probably will make a more nice waveform, with less inductive effect on probe
Offline plazma
    • Homepage
« Reply #28 on: June 18, 2017, 09:19:28 am »
Are you using the original edux model probes? Weren't they only 70Mhz?
« Reply #29 on: June 18, 2017, 09:41:17 am »
Tk do you have access to a Siglent 100Mhz arb generator?
Would be interesting to make a comparative in another scenario based on signals from that generator
Offline TK
« Reply #30 on: June 18, 2017, 01:20:55 pm »
I am using the 200MHz probes from the micsig.  I will retest on the Keysight with the stock 70MHz probes.
Offline TK
« Reply #31 on: June 18, 2017, 01:24:53 pm »
I don't have a Siglent arb generator.  I have a Rohde & Schwarz CMU200 with RF signal generator (up to 2.7GHz) and the EDUX1002G with 20MHz wavegen.  I can do AM/FM modulation on both of them.
Offline Fungus
« Reply #32 on: June 18, 2017, 01:43:06 pm »
Keysight ships 70MHz probes? Seriously? How do they even manage to make them that bad?
There's a thread on here somewhere testing the cheapest cheap-ass Chinese probes ever and they were fine up to 300MHz.
https://www.eevblog.com/forum/reviews/cheapest-100mhz-oscilloscope-probes-hands-on-review/msg99256/#msg99256
Edit: I think we have the answer: https://www.eevblog.com/forum/testgear/new-keysight-scope-1st-march-2017/msg1220323/#msg1220323
« Last Edit: June 18, 2017, 01:45:41 pm by Fungus »
Offline TK
« Reply #33 on: June 18, 2017, 03:06:53 pm »
The link shows the Keysight 200MHz probe that is shipped with the DSOX1000 models.  The EDUX1000 models ship with 70MHz probes because it is a 50Mhz scope.
Offline Fungus
« Reply #34 on: June 18, 2017, 03:53:03 pm »
All true, but irrelevant.
I'm just wondering how anybody manages to make a probe that only goes to 70MHz these days.
ie. Is it really possible to save enough money to make up for the extra costs of manufacturing/stocking multiple probes?
Offline Fungus
« Reply #35 on: June 18, 2017, 04:03:57 pm »
Cynical Fungus might suspect they actually lose money by making really bad 70Mhz probes but make up for it by doubling or tripling the price of their 'premium' 300MHz probes.
