Author Topic: advice needed 34401A or siglent SDM3045x?  (Read 1410 times)
Offline marmelade
« on: September 09, 2018, 09:03:41 pm »
Dear Forum,
I am currently looking for a Bench-DMM, that fits my needs.  One of the main applications, apart from general bench use, will be testing DCDC and ACDC converters. Accuracy-wise 4.5 digits will be more than sufficient. Simultaneous display of DC-Current and DC-Voltage (often called dual-display) for eff. estimation would be a HUGE bonus. Since I am also aiming at automation, GPIB and/or LXI are welcome, a serial interface would be mandatory.
Now setting the budget to around 400 euros, I am facing the following options:
* A used 34401A, qood quality meter, no dual display, only 3A Current range, GPIB-interface
* A used FLUKE 45, 10A current range, GPIB per option available, very old
* A new Siglent 3045X, dual display and current range up to 10A and LXI-interface
* A new GW-Instek GDM-8341 4.5 digit meter with dual-display and usb-serial-interface
Dismissing the FLUKE (400 is imo very expensive for the age of the instrument) and the GW-Instek (I'd prefer a proper GPIB or LXI Interface over the usb-serial stuff). I am torn between the 34401A and the Siglent. Normally I'd rather aim for high quality, but used, than for cheap new equipment but the dual-display option and the high current range seem very appealing to me for general bench use (without automation involved).
What would you do? Any siglent users? Thank you very much for your input!
Offline tautech
Re: advice needed 34401A or siglent SDM3045x?
« Reply #1 on: September 09, 2018, 09:11:55 pm »
The Siglents while able to do dual measurements can't do simultaneous V and A. Instead they cycle between measurement types.
Even the 16ch logging card/module for their 3055 and 3065X operates in this way.
Check the specs carefully between 3045 and 3055 as IIRC there are differences that make a 3055 the better choice.
Avid Rabid Hobbyist
Online nctnico
« Reply #2 on: September 09, 2018, 09:16:17 pm »
For your budget you can buy 2 Vici 8145 bench DMMs. These have a serial interface (the protocol is somewhere on the forum) and with two meters you can measure voltage and current simultaneously.
Offline marmelade
« Reply #3 on: September 11, 2018, 09:18:26 pm »
Sorry for the late reply, life kept me buisy over the past 2 days.  Thank you very much for the suggestions. I also had a second look at the dual-display capabilities of the Siglent devices. Not the same, but similar.
Giving the whole matter a second thought, I am currently leaning towards buying the 34401A. Current ranges can be extended by external 10m or 1m shunt resistors.  Also the dual display-switching via relays is probably not the most relaxing working environment ;).
Offline tautech
« Reply #4 on: September 11, 2018, 11:07:31 pm »
I don't know which bench DMM's don't operate in this way for V & A dual measurements. Best you research this well or use 2 meters.
Avid Rabid Hobbyist
Offline coromonadalix
« Reply #5 on: September 12, 2018, 02:15:44 am »
If you want an true dual isolated channel bench meter  there is one $$$ :  ADCMT DMM 7352A  (A channel : 10pA to 2A and  B channel: 100μA to 10A)  not for America and Asia ???
Cant recall the other brand i saw ...
Offline bitseeker
« Reply #6 on: September 12, 2018, 02:20:24 am »
DMMs that measure V and A simultaneously are pretty rare, which usually means they'll be expensive. Just use two meters. It's good to have a backup DMM anyway.
On the 34401A, make sure that there are no dots lighting up that shouldn't be illuminated. That's a sign of display problems.
I TEA.
Offline marmelade
« Reply #7 on: September 12, 2018, 07:13:47 pm »
Yeah, the more I am thinking about it, the more am leaning to having two seperate meters. It just makes more sense.
Offline marmelade
« Reply #8 on: September 18, 2018, 05:28:34 pm »
Just to finish this... found a used FLUKE 45 for an acceptable price. I*ll add a second meter soon, but I am not decided on the model yet. In the meanwhile I can rely on the dual-display feature of the old FLUKE.
Thanks a lot for all your input!
Offline bitseeker
« Reply #9 on: September 18, 2018, 05:36:52 pm »
Very nice. Thanks for the update. Happy measuring!
I TEA.
Offline Electro Fan
« Reply #10 on: June 03, 2019, 03:49:37 am »
Old thread I realize but I'm betting tautech finds this :)
The attachment below from the Siglent manual indicates it does a dual display of V and A.  Just checking to see what this means given your previous post above....
Alternately means that the DMM measure A then V then A, etc and displays the results, so they are not realtime simultaneous, but interleaved over some (TBD) duration?
Thx
« Last Edit: June 03, 2019, 03:55:46 am by Electro Fan »
Offline tautech
« Reply #11 on: June 03, 2019, 05:23:03 am »
Thx
Correct, ~1 reading/s alternating between the dual measurements selected.
I don't see a spec in the datasheet for the frequency of each reading while in Dual mode however it's ~1s, so each measurement type is taken every ~2s.
P53/109 lists a table of the dual measurements that can be selected.
http://www.siglentamerica.com/wp-content/uploads/dlm_uploads/2017/10/SDM3045x_UserManual_UM06034-E01A.pdf
Avid Rabid Hobbyist
Offline maginnovision
« Reply #12 on: June 03, 2019, 06:19:57 am »
Also R&S have the HMC8012 that does V/A without clicky relays. Not exactly pertinent information now but thought I'd add it here since it was part of the discussion and the thread came up.
The following users thanked this post: Kean
