Recently I read quite interesting article about controlling high current pulses from supercapacitors using IGBT device.
Unfortunately it's written only in polish:
http://www.portalnaukowy.edu.pl/index.php?option=com_content&view=article&id=229%3Asterownik-duego-tranzystora-igbt-do-superkondensatorow&catid=51%3Aelektroprojekty&Itemid=120&limitstart=1What caught my attention is an interesting feature on Tektronix oscilloscope on one of the photographs.
As you can see in the upper right cornerof the image the delta value (difference) between cursors positions is expressed in amperes and in this example has a value of 1.47 kA! I was wondering if Rigol DS1000Z series scopes also has such feature. I checked the manual and I was playing around with it for a while. From what I found out it seems that it is possible but there are some limitations. You can change displayed units but there are only four options: W, V, A, U. To change the scale, for example if I want every 1V on the input to be displayed as 10A on the screen I need to change the probe multiplier/divider.
But there is one major drawback - you cannot put any value you want, for example if 1V should be displayed as 4A or 17A, etc.
How is that solved on different Rigol scopes and on other manufacturers devices?
Do you have any other suggestions how to solve that "problem"? (well, that's not exactly a problem, I'm just curious
