Products => Test Equipment => Topic started by: W100 on March 15, 2019, 06:00:31 am
Title: RIGOL DS1054Z firmware 00.04.04.SP4
Post by: W100 on March 15, 2019, 06:00:31 am
RIGOL DS1054Z. Firmware from delivery 00.04.04.SP3. All Options are open.100 MHZ no. Have installed firmware 00.04.04.SP4. I want to do 100 MHZ. Invalid license. Help. RIGOL company woke up? Sorry for my bad English.
Title: Re: RIGOL DS1054Z firmware 00.04.04.SP4
Post by: t_i_t_o on March 15, 2019, 08:20:52 am
Just updated one DS1Z to 100MHz. Double check the serial number you entered and everything should be fine.
Post by: W100 on March 15, 2019, 01:07:20 pm
Checked several times. Can you roll back to the old firmware?
Post by: newbrain on March 15, 2019, 01:36:01 pm
Not easily.
But there's been no report of the new FW preventing the unlocking (and updating an already unlocked scope works, IME).
It would seem very strange to close the stable doors 5 years after this horse has bolted... :=\
Things to check:
All this and more is described and linked in this post (https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/)
Post by: W100 on March 15, 2019, 03:03:11 pm
newbrain
Thank you!
Used only DSER.
No unlocking via SCPI (over telnet/USB).
I will try. After all report.
Post by: W100 on March 15, 2019, 03:30:24 pm
Thank you very much. 100 MHZ works. My bug: there were dots after the serial number.
Post by: Housedad on March 15, 2019, 05:38:14 pm
You added the dots?  That is why it did not work at first?
Post by: W100 on March 17, 2019, 10:36:22 am
No. They just stayed at the end, I didn't delete them.
