Author Topic: RIGOL DS1054Z firmware 00.04.04.SP4  (Read 4738 times)
Offline W100
  • Country: ru
« on: March 15, 2019, 06:00:31 am »
RIGOL DS1054Z. Firmware from delivery 00.04.04.SP3. All Options are open.100 MHZ no. Have installed firmware 00.04.04.SP4. I want to do 100 MHZ. Invalid license. Help. RIGOL company woke up? Sorry for my bad English.
Offline t_i_t_o
  • Country: bg
Re: RIGOL DS1054Z firmware 00.04.04.SP4
« Reply #1 on: March 15, 2019, 08:20:52 am »
Just updated one DS1Z to 100MHz. Double check the serial number you entered and everything should be fine.
Offline W100
  • Country: ru
« Reply #2 on: March 15, 2019, 01:07:20 pm »
Checked several times. Can you roll back to the old firmware?
Online newbrain
« Reply #3 on: March 15, 2019, 01:36:01 pm »
Not easily.
But there's been no report of the new FW preventing the unlocking (and updating an already unlocked scope works, IME).
It would seem very strange to close the stable doors 5 years after this horse has bolted... :=\
Things to check:
  • Have you tried only the web site or also downloaded and used the binary? Some people got different results, AFAICR.
  • Have you used the DSER code? Do not use DSFR!
  • Did you try unlocking via SCPI (over telnet/USB)?
All this and more is described and linked in this post
Offline W100
  • Country: ru
« Reply #4 on: March 15, 2019, 03:03:11 pm »
newbrain
Thank you!
Used only DSER.
No unlocking via SCPI (over telnet/USB).
I will try. After all report.
Offline W100
  • Country: ru
« Reply #5 on: March 15, 2019, 03:30:24 pm »
Thank you very much. 100 MHZ works. My bug: there were dots after the serial number.
Offline Housedad
« Reply #6 on: March 15, 2019, 05:38:14 pm »
You added the dots?  That is why it did not work at first?
At least I'm still older than my test equipment
Offline W100
  • Country: ru
« Reply #7 on: March 17, 2019, 10:36:22 am »
No. They just stayed at the end, I didn't delete them.
