Thanks to this blog I decided to buy an oscilloscope. It is my first scope, Goldstar OS-9020A. It's almost brand new, very hardly used if not at all. Inside I see nothing has been repaired, all the caps looks good.
How do I check is it working properly? Maybe 5 minutes after turning on whe it heats up a little bit the trace rotates for maybe 2-3mm, probably some cap is slightly off but I couldn't find any is wrong. Also when TIME/DIV is set to 2ms or less the trace become flickering, the more you go down the more flickering it is. Is it normal or not?
Also could anyone help me with service manual? It came with user manual but it's on German language and with original probe that came with it.
